Help Code p0420 help
Old 02-11-2019, 07:53 PM
shawnb1989
shawnb1989's Avatar
Code p0420 help
CEL light on, code p0420 means catalytic converter. Hoping it might be something else any thoughts? Btw 2013 g37x sedan 85,000 miles
Old 02-11-2019, 08:37 PM
stealthee
stealthee's Avatar
P0420 means the cat isn't doing it's job.
Old 02-12-2019, 08:51 AM
shawnb1989
shawnb1989's Avatar
Anyone know where to find new cats? And how much it might cost? Sorry don’t know much about this stuff. Also not opposed to an upgrade
Old 02-12-2019, 10:56 AM
Baadnewsburr
Baadnewsburr's Avatar
before running out and getting a set of new cats, the code is only for the passenger side and it could also just be an exhaust leak or an 02 sensor gone bad..if you change an O2 Sensor its a good idea to change them in pairs (i..e change the matching o non the other side as well)
if you do need new cats the best place to get them is in the classified on here form other members or your local craigslist
anyways good luck and post up how you solved your problem!
Old 02-20-2019, 06:45 AM
shawnb1989
shawnb1989's Avatar
i actually just used some catalytic converter cleaner and drove around for a week and no more CEL. However car still idles rough and had bad gas mileage.
Old 02-20-2019, 09:05 AM
Baadnewsburr
Good to hear that the CEL is gone hopefully it stays that way....keep in mind if the sensor is bad or there's a leak the car will adjust the A/f ratio to compensate on that bank...it can cause the rough idle and bad mileage too
Old 02-20-2019, 10:40 AM
shawnb1989
shawnb1989's Avatar
I tried check for any air leakes but found nothing even did a smoke test. Do you think I should just change the 02 sensors?
Old 02-21-2019, 01:13 PM
Baadnewsburr
If it were me I'd plan to change the 02 sensors just to be safe but I'd also take a quick look at the spark plugs too as the plugs may have been running hot for a while due to the bad sensor and may be bad at this point too ...changing the plugs if they are bad may even immediately fix the idle and mileage issues even without changing the O2 sensor but it might be temporary if the sensor is not changed too and it may prematurely ruin another set of plugs
Old 02-21-2019, 03:23 PM
shawnb1989
shawnb1989's Avatar
thanks I’m about buy a set of spark plugs and O2 sensors today
Old 04-06-2022, 10:42 AM
tripps6x
tripps6x's Avatar
did you ever get this fixed? I have same problem and dealer wants 1800$ to fix 1 cat. 3200$ for both
Old 04-28-2022, 06:22 AM
stealthee
stealthee's Avatar
Originally Posted by Osama_STI
last thing you check is the catylitic itself since the car is not 30 years old.. when i had this code a lot of comments and websites kept confusing me and making it a big deal.. it was just sensor. When you have an electrical code first thing you consider is SENSOR.
Just because the cat isn't old doesn't mean it can't fail prematurely.
Osama_STI (07-01-2022)
GDriveAlot
06-09-2019 07:10 PM
jkim972
10-01-2017 01:10 AM
Bmxr215
Intake and Exhaust
08-27-2017 10:19 AM
V36Skyline
General Tech Questions
01-16-2012 06:06 PM
Quick Reply: Help Code p0420 help
