Catalytic converter rattle, covered?
Old 10-09-2018, 12:40 AM
derekjl
derekjl's Avatar
2013 G37x, 7AT. Just recently I noticed what very much sounds like the infamous catalytic converter rattle. It only happens at idle to about 1,500rpm, doesn't matter if car is in Park or in Drive, etc. It isn't coming from the engine bay, seems to be right under the driver's seat or passenger's seat. I have a CPO warranty. Is this type of thing covered? I also understand that there is some kind of federal warranty for 8 years and 80k miles? I definitely didn't expect this to happen with 50k miles on the car. Any input is appreciated.
Old 10-09-2018, 01:18 AM
slartibartfast
slartibartfast's Avatar
The Federal warranty covers the operation of the catalytic converter. The heat shield has nothing to do with clean air.
As for CPO, check your contract or contact your dealer.
Old 10-09-2018, 01:20 AM
derekjl
derekjl's Avatar
So it is the heat shield rattling or is it the internal parts of the converter? I was under the assuming that the rattle has to so with the "waffle" inside coming apart.
Old 10-09-2018, 01:21 AM
slartibartfast
While there have been instances of the substrate cracking in the converter, Occams Razor points towards the heatshield. It seems to be a rather common issue.
Old 10-09-2018, 01:29 AM
derekjl
derekjl's Avatar
I'd have to assume that the heat shield is PART of the converter itself and can't be replaced and/or adjusted? Either way I have an appointment for next week. I sure hope it is an easy fix.
Old 10-15-2018, 05:10 PM
derekjl
derekjl's Avatar
Update: Went to dealership this afternoon. Driver's side catalytic converter is bad. They knew within about 5 minutes. The replacement will be totally covered by the emissions warranty. They gave me no hard time at all about needing a CEL or code in the computer. I'm a happy camper!
Old 10-15-2018, 07:09 PM
slartibartfast
Good for you. I can breathe easier now that your exhaust is cleaner (bad pun most definitely intended).
Old 03-14-2019, 06:58 PM
flipmode007
flipmode007's Avatar
The replacement will be totally covered by the emissions warranty, wow I wished we had this in canada lol
SpeedBallDEVIL
16
09-02-2022 08:26 PM
SRTst
Intake and Exhaust
12-28-2014 09:32 AM
TicketProof
Intake and Exhaust
06-09-2011 02:14 PM
ScottyBeGood
Intake and Exhaust
20
04-18-2011 09:05 PM
Quick Reply: Catalytic converter rattle, covered?
