Admin Vs Stillen Vs Takeda Intakes
I've been searching and all I can find is conversations about them. But I haven't found any direct data i.e. dyno, etc. Especially takeda don't hear any reviews on them.
Stillen Gen 3:
https://www.stillen.com/stillen-infi...it-402846.html
Takeda Stage 2:
https://afepower.com/afe-power-ta-30...-intake-system
Admin 3":
https://www.administrationtuning.com...t-p/hrmaf3.htm
Just wondering has anyone seen any difference on hp i know it aint a lot but all three have different prices. Need to know if all intakes make the same numbers cause why buy expensive intakes if it makes the same power as others.I know on the adminintakes supposedly makes great power and from seeing the results thats pretty big number for just the intakes thats why curious about them i know intakes wont make that much of a difference or am i wrong. Unless the 3" tubes make a difference of the air volume going to the throttle.
Stillen Gen 3:
Takeda Stage 2:
Admin 3":
Theres like 1-2 Admin intake threads with a bunch of info. I think one here and another one was made in technical section.
tl;dr admin intakes perform the best but need a tune to run. Does not run without a tune. Also recommend bigger throttle bodies.
Stillen is next best performing as it has steel elbow joints. No airflow cut like in the pvc.
takeda is basically just like stillen's with pvc elbows and 1 single filter vs 2. Worst performance as the pvc elbow gets bent and restricts airflow. I'm thinking about cutting my intake inlet.
Admin will grant largest gains in power but, like kroy mentioned, you need bigger TBs and a tune to take full advantage of them. So all of that needs to be taken into account when calculating the total cost of the set-up (aka: $$$). Gen 3 are middle of the road but were arguably the best intakes before Admin intakes came along. Need to cut rad. support to make them work but they're plug and play basically. Kroy said all that needs to be said regarding Takeda.
sales@czp
Engine/Intake/Exhaust
117
02-15-2018 04:58 PM
