Help FI rhfc vs Art pipes
#46
not sure on the cracking issue though.
You cannot go wrong with either choice but If your only goal is power then go with test pipes.
no cel for me ^_^
#47
most of those points are not relevant anymore since the art pipes came out with v3 with titanium coating and better welds.
no cel for me ^_^
no cel for me ^_^
Bun_Bo_Hue (03-25-2014)
#49
If you are looking for max hp and torque for your money go with the ART pipes. They also create an unbelievable exhaust note when paired correctly.
They are well tested and engineered. The side branch resonators are created to reduce rasp better than any test pipe out there and create low end torque. On my other car I swapped out Berk HFC's to ART pipes and gained both HP and Torque.
#50
Can anyone confirm post #20- 1cleanG: "...You gain power with all of them, but you do NOT gain as much TQ from ART pipes vs RHFCs. The midrange TQ from 3k-5k is anywhere from 3-5 ft/lbs of torque lower with the ART pipes. You also don't see HP gains any higher anywhere in the powerban more then 2-3 hp extra from the ART pipes vs the HFCs..."
#51
if you are going with FI exhaust, i suggest you go with FI double resonated test pipes instead of art pipes. The workmanship of the FI products are much better than motordyne see the thread posted by 1cleang which shows motordyne vs FI test pipes, quality of the welds etc.
motordyne pipes always had some issue or the other which is why they kept releasing newer versions v1,v2,v3
i myself run FI exhaust with art pipes, but having heard FI exhaust + FI double resonated test pipes, i must say the full FI combo sounds far better. about the gains I am not sure, but 2-3hp is not noticeable enough for that to be a deciding factory
The following 2 users liked this post by Presto:
Bun_Bo_Hue (03-25-2014),
G37Sam (03-25-2014)
#52
I noticed a bit of childness and personal attacks in this thread. If you can't differ in a mature manner please steer away from the discussion. It will not be tolerated.
#54
FI+FIDRTP has a more deeper tone and is louder than FI + ART.
I do not have videos of either combo
one thing i noticed was the fidtrp hangs lower than the art pipes (atleast an inch), so if you are slammed you will scrap over bumps, but then again art got some weird fitment depending on which version you buy and which batch it was produced in so YMMV.
#57
Just installed my FI RHFC's, absolutely love them. Honestly, I probably would have gone with test pipes, resonated test pipes or even ART pipes, if I thought I would pass inspection. A kid in my car club, with ART pipes or test pipes did just pass inspection, but I didn't want to chance it. I love the sound of the RHFC's, there is a little noticeable power difference too.
After installing the Gen 3, the sound of the VQ changed, adding the FI RHFC's made it sound like the VQ again, but even better. I'm very happy with the route I took, and I hope I pass inspection in August, I assume I will. Is there a break in period for these.
I think no matter what you go with you will most likely be happy, if not for anything else, buy the fact that most of us (most of us) aren't able to try multiple setups, so most of us have OEM to whatever we choose for comparisons, so I think whatever someone chooses, most of the time (most of the time) they will like it.
But does anyone know the break in period or if there is one for the RHFC's?
#58
I had FI RHFCs on for 2 years and had to recently take them off to pass Calif smog. Anyway, I wasn't aware of a *break in period* for these. Tony put them on himself and never mentioned it to me.
#59
Ok, I have a question for all of you guys here and hope someone can help me out?
I have a 2008 g37s coupe and running a ARK exhaust system on the car. Just last week I install the BERK hfc on them. I hate the hiss sound and also giving me a check engine light. The one good thing I like about the BERK HFC is that the power is very noticeable on my set up now. So I was thinking of changing it to FI HFC or ART pipes. Which one of these 2 will give me good power and no check engine light. Thanks !
#60
1. I had a bad experience with FI catback v1 which got chocked in the past.
2. FI HFC cells collapsed.
3. Cracked FI "2.5 test pipes ( just nearby the 3 bolts flange ).
All these happened in the past before i stroke my engine.
Now the whole exhaust setup is changed.
Lesson i've learned : Don't count on forums feedbacks all the time ( sorry for that )!
99% of the crowed here swear by FI products but soon you find them in Private classified sections carrying some of their FI stuff .. Especially their RHFC!!!
