Tanabe owners axle back - question
If you were to do it all over again would you go axle back or go cat back? If so why either way?
Also is the sound improvement over oem over time. Everything I have heard are from people who newly installed the exhaust. I'm curious to see if it turns out over time to sound becomes the same as oem. Thanks |
I have Tanabe full Catback I wouldn't go any other route! Tone is
Originally Posted by VossenG37S
(Post 3231555)
Unfortunately I have a x sedan... Which is why I am asking about axle back tanabes.
(Post 3231555)
(Post 3231555)
Originally Posted by Samurai
(Post 3231591)
Do you know if the full cbe is compatible with the X coupe?
Originally Posted by mikelebron
(Post 3231612)
Originally Posted by wakeboardr116
(Post 3231616)
+1. I've had several different combos. axleback, axleback+ ypipe, and full catback and love them all. Full CBE with cats is hands down the best. I wouldn't change it for anything.
It could be. The tanabe is very close to OEM as far as design of the system goes. The only thing I'd worry about is the y pipe. It is shaped quite a bit different than OEM. You could to the axleback + mid pipe. I want to run the CBE though. Ill contact someone that works at Tanabe and see what they say in the morning. |
Contact JEPerformance they now carry Tanabe products, sedan is diff so I'm not sure but pm JEB! I can't wait to take my cats off my car Tanabe is the
If the Tanabe y doesn't fit you could also try a different y pipe. I know the Ichiba is shaped almost identical to the oem. It's just a 3" outlet instead of 2.75" like the Tanabe.
(Post 3231626)
(Post 3231627)
How much you think Ichiba's y-pipe goes for? |
(Post 3231629)
(Post 3231639)
Amp'd has it for 269. I've actually got one in my garage just the flex joints are all scraped up and need to be replaced. I had this with the Tanabe axleback before the full CBE came out.
Guys slightly off topic.. I'm only asking for a x sedan. I'm also only interested in how the exhaust sound breaks in. Does it end up sounded mo better than oem? Better over time or stays the same as when you first installed it?
If ther are other parts outside the muffler itself I'm interested but only for a x sedan. |
Alright so I called Tanabe USA and they said if the y-pipe for the RWD and the AWD have the same part number then their y-pipe will fit. Now I will call my local dealership and find out.
Y-pipe for the RWD and AWD are different.
