Go Back  MyG37 > Tech Area > General Tech Questions
Reload this Page >
Does it sound healthy? Is that sound normal?
Notices
Old 12-06-2018, 11:26 AM
  #31
slartibartfast
When the throttle is whacked open, AFR goes lean momentarily, not rich.
Throttle hang used to be endemic in the late-70s and the '80s until car makers got the necessary hardware to make EFI work right. That doesn't mean tour G is acting correctly, though.
slartibartfast is offline
Old 12-06-2018, 11:33 AM
  #32
Vq_Jordy
everytime I turn the car off and then I turn it on, it doesnít do it, so the problem is ecu related , it has to be
Vq_Jordy is offline
Old 12-06-2018, 12:00 PM
  #33
RMB5190
Yea that's where I read about it but the most recent example was with a 2012 Yaris so I thought maybe it could be the issue being described.
RMB5190 is offline
Old 12-06-2018, 12:03 PM
  #34
RMB5190
Originally Posted by Vq_Jordy View Post
I am the second owner of the car!! And how would you reset it?,if this is the problem, my car is a 6spd manual by the way just putting it out there!
I just Unplugged the battery (installed my grounding kit at the same time), cleaned my throttle bodies and after hooking everything back up I did the pedal position and throttle re-learn procedure.
Starts at :45s mark
My hope is, my doing this you will see the throttle RPMS react normally as his does (4:55 mark) vs the hang you experiencing.
RMB5190 is offline
cole10
Engine, Intake and Exhaust
13
01-13-2018 05:04 PM
01-08-2017 03:19 PM
Goonz
12-07-2016 10:34 PM
Steve M
11-28-2016 06:14 AM
Quick Reply: Does it sound healthy? Is that sound normal?
Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
