BCM Sleep and battery drain
When I bought the car it had a dead battery; not a big deal it was in an accident and the washer reservoir got knocked off so the wires were shorting out. I taped the wires for now but when I check with my multimeter it shows 700ma, how long does it take for the BCM to go to sleep to get a correct reading? When I did a search the only thing I could find is someone saying 45 minutes but that seemed kind of long. My 335i takes about 15 minutes and my lancer is within 30 seconds -- 45 minutes just seemed a bit odd.
Thanks in advance |
Broken and shorted wires should have popped fuses so check through those.
What exactly are you checking with your multimeter? The BCM's "battery saver" function is meant to shut off any room lamp or exterior lights left on by mistake. It may only be tied to lighting because everything else should be powered down within 30 seconds of shutdown (elec. windows have a slight delay). BCM factory default is "on" (save the battery) but it can be programmed to "off" (kill the battery). There is also a room lamp timer circuit which can be set to 15, 30 or 60 minutes. Factory Service Manuals are here: Infiniti G35 / G37 Factory Service Manuals - NICOclub Choose your year and model and dig in! |
They should have, but unfortunately they were just slowly kill my battery. With the multimeter, I was checking for parasitic drain on the battery. It was showing that while off it was using 700mA which is too high (usually under 100mA is normal).
I found and taped up the washer reservoir pump and level sensor wire that were ripped in half and touch near the radiator support and the fuses were still good and when I went to replace the driver side seat belt I found that when the seat belt's charge went off it shattered the side of the seat belt housing off and cut some wires in half also. I taped up those wires for now and it dropped to 200mA. After 20 minutes it looks like the car went to sleep and it finally went below 100 mA. I should be good now. I ordered the connectors I needed last friday and will be soldering them this weekend. The factory manuals are great! I keep all 3 of my cars' manuals in my garage. |
Originally Posted by Genhero
(Post 4182739)
... when I went to replace the driver side seat belt I found that when the seat belt's charge went off it shattered the side of the seat belt housing off and cut some wires in half also. I taped up those wires for now and it dropped to 200mA.
As I use a voltage logger I can see that sometimes the car didn't went in sleep mode (recognized by a dimple in the voltage graph). I have a consult III but can't find any problems. I can't also figure out a pattern so in kinda lost here. |
