2009 7 speed trans fluid change
Looking at draining and refilling the 7 speed trans fluid. Draining it appears to be pretty simple, drain plug, but was curious if it could be refilled by adding fluid via the trans fluid return cooler line. Refilling with exactly what comes out so it won't be under or over filled. Not looking to pump it back in via the overflow port as stated in the service manual. Thoughts
Look in the drivetrain forum and the D.I.Y. Forum for tutorials.
Originally Posted by duffster
(Post 4167468)
