Oil change necessities
Wanna start changing my own oil since I have a garage now
Know basics of oil change
What would I need to make it easy every oil change
Oil
Oil filter
Oil filter wrench
Hydraulic jack ??
Jack stands better or the Ramps
Car is lowered with coilovers 26.5 Fender To Ground
With the car lowered would ramps be ok
Ultimately whats the best synthetic oil besides royal purple
How often should I change oil
3000 or 5000
Oil
Oil filter
Oil filter wrench
Hydraulic jack ??
3000 or 5000
Don't forget wheel chockes.
Kpmikey808 (06-25-2017)
i like the "big cookie sheet" because its all about speed and convenience - no spreading out a tarp - i just slide it out from under my workbench and under the car - catch container, oil filter wrench, and funnel is already sitting on it ready to go. jack up passenger side, proceed with draining (the longest part) ... while its dripping out i use that time to detail engine bay, clean wheels, etc.
only downside is it takes up more space than a folded tarp unless you have somewhere to lean it up against a wall, or in my case, a work bench to slide it under.
Kpmikey808 (06-28-2017)
Those ramps look like they weigh 100lbs or more! Jack and stands for me. When do you guys rotate your tires? I do it every oil change, and can't do it with ramps. Really only go 3k on the mobil1. I fully expect this to be too soon for ALL of you but, I only drive it like 6k over the summer so it works for me.
I rotate my tires every 7k, and the ramps make it easy to get my floor jack under there then get to rotating
Here's the pic of my ramps, don't weigh much and you can store them stacked upright (inversed) and they don't take up much room. As far as change intervals and what oil to use, if 3k on synthetic is what you prefer, nothing wrong with that.
When you guys rotate your tires, do you guys reset the TPMS sensors?
- go to the dealer every time you need to rotate tires
- deal with the fact that the TPMS displays are going to not indicate the correct tires
- buy some sort of TPMS programmer ($$$?)
don't mean to derail the thread, but i haven't considered this ... rotating tires on an AWD vehicle is important, and i guess you'd have to either:
Well, I go with option 2. I check my tire pressure, engine, etc.. every Sunday evening as part of my weekly car check for each of my vehicles (hence I asked if anyone reset their TPMS sensors). Some may think I am cheap...but my philosophy is that I don't mind spending money, but I hate wasting money. =)
i'm also not cheap, and not stupid, either. i deal with the low tire pressure warning all winter with my snow tires (no TPMS sensors on them), but check the pressure every week or so.
would anyone recommend a good hydraulic jack? I've been looking online & amazon and see that some hydraulic jacks leak out their oil & some the bolts snap in half
some talk about after 3-4 oil changes the jack doesn't function as well
The Harbor Freight 3 ton low profile jack is a good one, never had any issues, many members here use them, and they can typically be found for about $80 with coupon.
I can probably dig up a coupon if you need one, shoot me a PM if so.
https://www.harborfreight.com/3-ton-...ump-61253.html
Kpmikey808 (07-31-2017)
#30
Good looking out B! That is a nice ! Mahalos 🤙
