Help Brake Warning Light
Old 05-27-2017, 11:04 AM
maduko
maduko's Avatar
Brake Warning Light
Last week under heavy acceleration the brake warning light on the dash came on. It went off after a few seconds.
The next day I tried to repeat it- and it came on again. This time for several seconds.
My first thought was it's low of fluid and the level sensor was tripping the light. But looking at the reservoir I see no float or sensor. At least not one I recognize. Anyone else seen this before? Any ideas?
Old 05-27-2017, 12:23 PM
Epiphany
Epiphany's Avatar
What was the fluid level in the reservoir? Likely still worth topping up and seeing if that fixes it.
Old 05-27-2017, 02:52 PM
stealthee
stealthee's Avatar
Just because you don't see a float or sensor doesn't mean it doesn't have one. Top off the fluid if it is low. Also if it is low then that likely means your pads are worn and probably about due for replacement,
Old 05-28-2017, 09:30 PM
maduko
maduko's Avatar
Fluid isn't low. And even if it was I don't think it's a "slosh event" anyway. I have tossed it around and stopped pretty hard without seeing a brake light.
Old 05-28-2017, 11:52 PM
stealthee
stealthee's Avatar
I've gotten the brake light on acceleration on a few occasions. It was always fixed by topping off the fluid.
Old 05-29-2017, 07:34 AM
maduko
maduko's Avatar
Good to know. I'll give it a try today.
Old 05-29-2017, 05:28 PM
Baadnewsburr
Baadnewsburr's Avatar
In case it wasn't clear for the other responses... there is a sensor in the MC that may also trip the VDC and Slip lights if the fluid gets low (VDC is tied to the braking system), the solution for all these issues, is to top off the brake fluid.
maduko (05-29-2017)
Old 05-30-2017, 02:44 AM
Melophile
Melophile's Avatar
What fluid to use to top off the reservoir?
I would assume it has to be the same as the fluid that's already in the reservoir. How do I know what fluid is currently being used?
Old 05-31-2017, 03:59 PM
g37x2013
g37x2013's Avatar
use DOT 3 brake fluid, you can pick the brand.
