Car just won't start
I'm not really sure if anyone posted this before or it has happened to anyone else. but my car won't start long story short my car was blinking when I came the next day to check my car I had a flat tire and my lights were on like it was on push to start like itself but couldn't start or does start it's stuck on lock mode or something it just won't start idk whats the problem.
Look at the video and thanks any help would be most appreciated https://www.dropbox.com/s/tzi6bnjmu9...22309.mp4?dl=0 |
Have you tried jumping the car with another car? Possible battery issue? This happened to me when a interior light was left on for a while.
Originally Posted by svclee
(Post 4107513)
Have you tried locking and unlocking the car with your KEY FOB? Is your KEY FOB battery still good?
What year and model is your G? Possible the vehicle immobilizer kicked in? |
(Post 4107522)
Do you have a constant small amber key light on on the dash ?
If yes, then it might be a problem related to S/L lock or NATS. Some error codes will help alot on finding what's the problem there... |
I couldnt hear but do you hear any clicking at all when pushing the start button?
Are you outside lights blinking when you try to start it? Are you not able to open the trunk with the switch inside the car? Most of these symptoms would lead to a bad battery, i would try jumping the car if possible even if you did switch out the batter. Other than that could be a Immobilizer issue which you may need to bring it to Infiniti to resolve? Though you can try putting your KEY FOB in the slot to your bottom left of the steering wheel then start the car? |
A proper scan tool that can read the error codes on that car will help alot on finding where the problem can be...
Originally Posted by Elco
(Post 4107547)
(Post 4107548)
Are you outside lights blinking when you try to start it? Are you not able to open the trunk with the switch inside the car? Most of these symptoms would lead to a bad battery, i would try jumping the car if possible even if you did switch out the batter. Other than that could be a Immobilizer issue which you may need to bring it to Infiniti to resolve? Though you can try putting your KEY FOB in the slot to your bottom left of the steering wheel then start the car? No blinking. I can open the Trunk. I tryed to jump it even changed battery don't help
(Post 4107562)
Brake switch failure?
Originally Posted by Turkmate
(Post 4107485)
Look at the video and thanks any help would be most appreciated https://www.dropbox.com/s/tzi6bnjmu9...22309.mp4?dl=0 Request a loaner & have the dealer call you when its fixed. End of problem Telcoman |
Originally Posted by Jsolo
(Post 4107842)
Originally Posted by telcoman
(Post 4107891)
Call AAA & have it towed to your Infiniti dealer
(Post 4107786)
I don't get error codes. and no.
Don't tell me you used some cheap bluetooth OBD scanner and torque app... because that won't give you any error code even if you had 100 errors... |
I'll post more videos.
| All times are GMT -4. The time now is 02:08 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
