Passenger mirror replace help?
1 Attachment(s)
Hi guys, i need help on replacing my passenger mirror, someone cracked it, anyways i bought the glass part only from infiniti, i just dont know if i can unglue it or do i have to take the tweeter apart and go from there ? Thanks in advance
I've disassembled the mirrors several times for different projects. No need to take the door apart. The glass just unclips from a plastic retainer. Basically you tilt the mirror all the way up and from the bottom you take a flat screwdriver and carefully pry the glass from the retainer. You will see the two notches where to pry. Once the glass pops off just unplug the two heater wires. They are on VERY tight. To install the glass, connect the wires, line the clips up and press hard until you feel the glass click into place.*
Page 51 for more detailed steps: Factory Service Manuals - NICO Club Hope this helps. |
Thank you bro, much appreciate the info, will do it tomorrow :)
