Originally Posted by G37nS2K
(Post 2577905)
i really wish my car was lemon so i can get a rid of it and get something else
More info'.........Revenge of the Nerd - Nissan in the sump with diamonds?
Originally Posted by cvt
(Post 2813285)
i hope so too G37nS2K because all you do is whine about your G37 and stroke your S2K at every post oppurtunity you get. i don't know who is hurting more...you owning a G37 or me having to read why you think the G37 sucks and how the S2K is the second comming of Jesus Christ...LOL :bowrofl:
Long Term Update
Hi Guys,
Haven't been here in a while so I wanted to give you all an update on this issue. After further research it appears TSB ITB07-048 was *my* problem. This is well documented and the "fix" is to reprogram the ECM. Dealer executed the TSB and problem disappeared for about 1 year. Problem came back this past August so I had dealer re-execute this TSB again. Problem seems to be gone again. I don't know if there is a permanent fix for this issue. I'm glad my lease on this vehicle is up in 3 months as I would not want to keep dealing with this dangerous problem anymore than I have to. Best of luck to you all. |
My 08 G37s(50k miles) has same issue. I just dropped it off at dealer this morning for the ECM reprogram, but seems the issue wasn't solved afterwards. Dealer gave me a lonar and told me will check again and call me back. Hopefully everthing is covered! Any of you guys fixed yours yet?
Does this TSB only apply to the 08 coupe?
