Transmission Mount Questions
After 5 years with the Z1 Polyurethane Transmission Mount, I'm considering going back to OEM. If you value the added NVH brought about with the Z1 mount, it's certainly a worthy mod. I mean, not all NVH is bad. And there's a valid argument about how shifting is improved when the drivetrain is more solid to the frame. I have no regrets. It was a $200 part, and maybe a 1-hour install. It's not a complicated mod. But lately I've been thinking I might like to soften things up a bit.
Now I'm pretty sure the original mount is up in the attic somewhere, but I got to thinking maybe I'd prefer to start fresh, with a brand new transmission mount. And that's where I have some questions. Is this part the same for the 6MT as it is for the automatic? Can anyone kindly find the part for me? Because I've not been able to dial into the exact part number on these InfinitiParts websites. I keep coming away frustrated and empty-handed. Here's a pic of the Z1 mount when it was new... just because pics are fun. http://www.johnclare.com/pics/cars/t...sion_mount.jpg And here's a pic of the original mount when it was replaced... looking kind of rusty and tired. You can see the difference easily between poly and a fluid-filled bushing. Interesting how the lower bracket is aluminum, just like the Z1, but the rest of it is steel. http://www.johnclare.com/pics/cars/sts_old.jpg That's the original shifter next to it, BTW. They were both upgraded at the same time. And yes, there's nothing between that greasy mess and my wife's table cloth but a thin paper towel. OMG, that was stupid... LOL |
Part#: 11320-1EA0A
Looks to be the same between auto and manual but I will let someone else confirm. |
exactly the same different part numbers
https://www.z1motorsports.com/engine...SABEgIMAfD_BwE https://www.infinitipartsnet.com/oem...SABEgJb__D_BwE |
That's a $70 difference between Z1 and that parts site. I wonder why that is?
Z1 is listing this as 11320-1EA0A, just like Rob posted. However that parts site is listing it as 11320-EG800. :dunno: |
(Post 4290512)
Z1 is listing this as 11320-1EA0A, just like Rob posted. However that parts site is listing it as 11320-EG800. :dunno: According to parts.infinitiusa.com, the 11320-EG800 is for: INFINITI EX35 2008, 2009, 2011, 2012, 2013, 2014, 2015, 2016, 2017 INFINITI EX37 2013, 2014, 2015, 2016, 2017 INFINITI FX35 2009, 2010, 2011, 2012 INFINITI FX37 2013 INFINITI G25 2011, 2012, 2013 INFINITI G35 2007, 2008 INFINITI G37 2008, 2009, 2010, 2011, 2012, 2013, 2014, 2015 INFINITI M35 2006, 2007, 2008, 2009, 2010 INFINITI M37 2011, 2012, 2013, 2014, 2015, 2016, 2017, 2018, 2019 INFINITI M45 2006, 2007, 2008, 2009, 2010 INFINITI M56 2011, 2012, 2013, 2014, 2015, 2016, 2017, 2018, 2019 INFINITI Q40 2014, 2015 INFINITI Q60 2014, 2015 INFINITI Q70 2011, 2012, 2013, 2014, 2015, 2016, 2017, 2018, 2019 INFINITI QX70 2014, 2015, 2016, 2017 So, what are you going to get? |
So... 1EA0A is for the 370Z, and EG800 is for everything else? I suppose that makes some sense.
Originally Posted by SonicVQ
(Post 4290520)
Get both, for research purposes of’course lol, and
return the one you choose not to use. It would be great if the 370z mount was stiffer than the factory G37 mount for those of us that don’t want the extra NVH an aftermarket mount brings with it. |
Originally Posted by 2.2Lude
(Post 4290530)
And assuming that the Z mount is somewhere in the middle between OEM and Poly... then perhaps the Z mount is the way to go. God damn it. LOL |
(Post 4290532)
Right, that's the question. Now that I know there are two: one for the Z, and one for every other Nissan.
And assuming that the Z mount is somewhere in the middle between OEM and Poly... then perhaps the Z mount is the way to go. God damn it. LOL Not ready to swap mine out yet (just other things have a higher priority), so looking forward to what transpires with this .......... |
Well it might be a while for me too. I'm very slow to do things between idea and execution. And at this point I'm still not 100% about the differences. The only serious bug in my head is the idea of ditching my poly mount.
Soo…bout that mount though..:)
Since you have a spare one, lets experiment.
Find it, drill it out and fill it with some poly of your choosing, since the install is not so complicated you could try to fill it and compare. By experimenting with your old one maybe you can find an "in between" between comfort and stiffness. |
Originally Posted by BULL
(Post 4307998)
Find it, drill it out and fill it with some poly of your choosing, since the install is not so complicated you could try to fill it and compare. By experimenting with your old one maybe you can find an "in between" between comfort and stiffness. And a year later, I've still not done anything and don't know if I will. Sorry. |
I have the same mount. I was thinking about putting different material in place of the polyurethane. Something in between the PU and the OEM boot filled gummies. These aftermarket mounts do come apart so you can put a filling of your choice.
I'm also not feeling the NVH that comes with the PU mount. I feel that the benefits do not outweigh the NVH. |
Originally Posted by spoolin03
(Post 4308324)
I'm also not feeling the NVH that comes with the PU mount. I feel that the benefits do not outweigh the NVH. I'm unsure about the harness of the transmission mount however if indeed is the same 70a as the motor mount this again starts to limit the limits of how soft you could go. Now the transmission mount helps more with side to side movement than weight balance unlike the engine mounts which take most of the weight. You could get away with a softer compound however I would not try anything lower than 60a if they make it. https://cimg0.ibsrv.net/gimg/www.myg...39c4b53daa.jpg https://cimg9.ibsrv.net/gimg/www.myg...2df514d321.jpg |
