Questions about LED Turn Signal Bulbs
A bulb swap in the turn signals is a cheap mod that's been bouncing inside my head for a while, and I'm still not solid on the topic. I've got the original amber incandescent bulbs in right now, with the Tail-as-turn-in module in the rear. Anyway, Peepz started this thread last month:
https://www.myg37.com/forums/body-in...od-review.html
...and since then, I've been interested in trying out these Oxilam bulbs:
They claim to have a built-in resistor, but if you research for experiences with these bulbs, the jury is out on whether it works properly, or needs an external resistor. I'm thinking the latter.
Also, Peepz said, "these only turn on when the turn signal is activated", when I'd like them lit whenever the headlights are on, just like OEM. Amber always-on with the headlights, and blinking bright amber when flashing.
If I do this, I want to just do it once, because of the PITA to pull back the wheel well liner for access. (Don't judge me, LOL)
Switchbacks... meaning white when on and amber when blinking? Nah, I like the amber look with my white car, matching the amber tint on my fogs.
And "canbus free" regardless, they warn about hyperblink when used too long, which is something I think all these bulbs warn about with a built-in load resistor.
http://www.lasfit.com/products/lasfi...n-signal-light
You need to get get something like that:
https://www.amazon.com/Alla-Lighting-Version-Extremely-Replacement/dp/B075LPT536/ref=sr_1_80?keywords=7440+amber&qid=1562725732&s=gateway&sr=8-80
You should listen what i say I wasted alot of money making my own lights and testing Chinese ones, so i have some experience.
Moderator in Moderation
You want replacements for the 7443 bulb, which is on/bright blink. 7440s and the like are just blink.
I have LASFITs as replacement back up bulbs and they're amazing. Can't find them on amazon any more though.
I got some sort of bulb for the tails, hoping they'd show amber. Ends up wrong wavelength, but otherwise they're pretty bright.
Edit: these They did NOT need a resistor, despite warning that they may.
Rochester (07-10-2019)
DIY Cheapskate/Mod
I've been running Morimoto switchbacks with external resistors for 2 years now, and they're fantastic. Always on mode is white light, and turn signal mode is amber light. Yes, its more expensive, but I've tried a few Amazon bans and none really lasted.
Also, for the turn signals, you don't need to pull the liners. Since you don't have the factory airboxes, you should be able to reach them by hand over the top.
I just re-read Johns question and realized my answer was not helpful at all, but oh well haha
Hey Rochester I found these lights for you that are just as bright as my Oxilams since they both use the 3030 LED chipsets. They are 7443 and are illuminated when the headlights are on.
Only thing is that they aren't "no resistors required" type of bulbs. As I stated in my previous thread, a resistor might be required no matter what. And like stated above, most LEDS not requiring one might be subject to overheating. We can't win either way.
https://www.amazon.com/AUXITO-Signal-Extremely-Bright-Replacement/dp/B07BLQZZX6/ref=sr_1_5?keywords=7443+led+amber+3030&qid=1562823813&s=gateway&sr=8-5
Rochester (07-11-2019)
https://www.amazon.com/AUXITO-Signal...gateway&sr=8-5
These look nice and seem extremely bright. In the reviews, there is a video that shows a comparison of old switchback bulb vs. these and from what i can see, they have a resistor installed to help keep the normal timed (slow) blink
So... seems I'm looking for 7443 Amber LED bulbs that are plug & play and CANBUS free. If that's not something out there right now, based on how products in this market have been evolving, it will be soon.
Then are are bulbs like this, which come pre-wired with an in-line resistor. What I don't understand is how the bulb end of the unit stays fixed into the headlight housing.
DIY Cheapskate/Mod
Hope I redeemed myself lol.
+1 for switchbacks (the ones that blink amber-off, I think called "type 2")
Kinda see why you'd prefer to keep amber to maintain your color-scheme up front...but switchbacks are one of the best ways to modernize our front-ends. Really underestimated how cool they look, especially when catching a reflection of the bulbs switching over. And running just the parking lights (something I didn't do prior) looks neat too.
Edit: Oh, and there are LED bulbs which still need an external resistor, but don't require you to splice into factory wiring. More of a plug-and-play design, but not built in to the bulb itself. Ex. VLED triton (I'm sure there are others)
