Tweeters
Hey guys I got a quick question, I simply want to add small rear tweeters n wanted to know if I can simply tap of the front tweeters that come with the stock bose system. Thanks in advance.
I see no reason why it wouldn't work, I'm curious to see how the project turns out
Once its complete I will post pics.
Check the Tech/Audio, Video, Electronics forum, too. |
(Post 4220693)
Isn't there a factory sound processor with the Bose setup? Wouldn't it mess with your highs?
Originally Posted by monytx
(Post 4220748)
you can do this but you will want to look into what resistors you will want to intall inline. These will work as a simple form of a xover.
Originally Posted by LIQUIDNEIL
(Post 4220757)
I remember there being a chart you can google. Just find out what the lowest tone you should have in those tweets and x refrence it with the chart
(Post 4220798)
Originally Posted by Redgoyabean
(Post 4220246)
Are you wanting the sound to be louder? The factory set up already has a crossover. Adding another crossover may not get you the results you want. You are also going to lower the final impedance. |
Originally Posted by blazeplacid
(Post 4220847)
You can do it but I wouldn't recommend it.
You can tap into the front pretty easily.
Where are you planning on placing the new tweeters? |
