anyone know what this leak is?
Old 02-07-2018, 12:19 PM
Mhang
Mhang's Avatar
Recently I've been noticing a little puddle being leftover whenever i back out of my spot in the garage. the color seems to be yellowish and pretty clear, similar to new brake fluid but I'm not sure. The leak is coming from right under the driver side. Any feedback or knowledge will be much appreciated.
I was able to tighten up the screw in the middle. seems to be loose so hopefully that will solve the problem.
Old 02-07-2018, 02:03 PM
JSolo
Just say no!!!!!
JSolo's Avatar
Does it smell like motor oil or brake fluid, or something else?
Old 02-07-2018, 02:25 PM
Mhang
Mhang's Avatar
It was hard to smell cause the odor wasn’t strong enough. Wiped up the small puddle with paper towel and tried to smell it but it was too faint. I checked my motor oil and I don’t think it’s that since it’s a little darker due to 3500 miles since my last oil change.
Old 02-07-2018, 03:01 PM
2010sedanS
2010sedanS's Avatar
Looks like your steering rack may be leaking....I had something similar and the steering rack was leaking. Dealer replaced under warranty.
Mhang (02-07-2018)
Old 02-07-2018, 03:10 PM
PNW_IPL
PNW_IPL's Avatar
what was your year and mileage?
Old 02-07-2018, 03:25 PM
Mhang
Mhang's Avatar
Damn, I’m guessing if that’s the case then I’ll probably have to replace it with a whole new steering rack. Seems Easy enough by watching videos on YouTube.
Old 02-07-2018, 04:04 PM
2010sedanS
2010sedanS's Avatar
2010, it happened last year around 58k miles....I had the extended warranty which just ended a few months ago
Old 02-07-2018, 04:53 PM
PNW_IPL
PNW_IPL's Avatar
I see. Mine leaks but was told I only have power train left and it doesn' cover it. 2013 42k
Old 02-09-2018, 12:07 PM
AARONHL
AARONHL's Avatar
Yea that's your steering rack. I would just leave it alone if there is no screeching noise coming from the engine and your steering wheel is still easy to turn...To replace it is expensive if you can't do it yourself. I mean its only like an hour job doing it yourself but the mechanics will chagre you outrageous amounts
Mhang (02-09-2018)
Old 02-09-2018, 12:21 PM
AARONHL
AARONHL's Avatar
Keep an eye on the power steering fluid level, if it keeps going down, you will have no choice but to replace it.
Mhang (02-11-2018)
mliakira
10-18-2017 09:28 AM
ECain18
06-19-2017 11:24 AM
4DRZ
Motorsports / Track
17
06-17-2016 03:03 PM
*ICE*
05-24-2016 01:39 AM
Quick Reply: anyone know what this leak is?
