Fog Light Housing Cracked
I had same thing happen this past September, found a pair on ebay that were exact replicas of the OE. Same fitment, same bulb. Replaced both and working looking great. Here is the ebay link:
https://www.ebay.com/itm/FOR-2010-20...item3f7d59068e
Did some more searching using the part numbers off of the parts.infinitiusa.com website. It appears the round lights with a flat front are for the sedan and that the round lights with a curve to them go to the coupe. Does not seem to matter sports vs. non-sport. At least with the few minutes of research I did. I chose the sport and non-sport and the part number is the same (same p/n for the sedans sport and non-sport) and (same p/n for the sport and non-sport coupes, but different than the sedan).
Retrofit source comfirmed the part numbers. The angled ones are for the coupes and the round ones are for the sedan. Sport bumper does not seem to matter. Bummer, since the angled ones are cheaper.
They have two for infiniti's....one is angled, that appears to be for the coupes and one is round, which appears to be for the Sedan and many other Nissan vehicles. The round one appears to match the part number from the infiniti website.
Just say no!!!!!
https://www.theretrofitsource.com/as...to-xb-led.html
That's the round one. Part number matches but their description says not for sedan's with sport bumper ¿? Very confusing.. I assume as a g37s sedan owner I have the sport front bumper right (it's oe, never been changed).
It can be done through the wheel well on the driver side. Washer fluid tank in the way on the passenger side. Passenger side can be done from underneath just removing the corner of the splash shield if you've got small enough hands.
Driver side... remove some of the liner clips and aggressively pull the liner off the fender just enough to get your arm in there. Be sure to turn the wheel inward.
Passenger side... run the car up on ramps, and go after the fog assembly from underneath.
Always good to research advice for something like this, but really it's one of those things that you just figure out as you go.
montyz81
16
11-30-2016 02:48 AM
Ali6767
06-30-2015 05:18 PM
