Clutch suggestions
Clutch suggestions
So this whole time my clutch was starting to slip. And I thought it was my engine on limp mode. Any suggestions on what kind of clutch I should get. No mods yet but plan on intakes exhaust and tune later on. It's a daily
In currently in the same boat. There are a lot of threads out there regarding clutch replacement. Just my $.02 is this. I have bolt on, i/e for now and I'm basically going to stay there. The kind of clutch you get is dependent on what you want to eventually do with the car and of course your budget. A lot of people here get a full kit, clutch, flywheel, clutch slave cylinder and master cylinder, along with stainless steel clutch lines, with everything costing around 2k, labor included. The slave cylinder is a must. I already replaced mine about 20k miles ago, I should have changed the clutch there and then but I'll be dropping my trans myself so labor is a non issue for me, just a pita a little. Slave cylinders fail in these cars, period. The fsm suggests replacing the master along with the slave, I changed mine since my slave blew out and probably sent shrapnel throughout the system which would eventually kill the master and slave again. If your slave is OK, I cant seem to understand why you need to replace the master but a new CSC is a must if you're in there. As far as clutches go, I'm going to the budget route. After doing some research, Luk makes a lot of oem clutches, including several for German makes. Partsgeek has a Luk clutch for our G's for about 175$ shipped. Can't beat that for basically an oem replacement. As far as the flywheel, im going to get the stock one resurfaced and I'm putting it back on as my mods won't require anything drastic. Most research on here will give you a non-budget minded answer as you'd expect from an enthusiasts' site but I thought I'd give this side of the deal. HTH.
Side note, I replaced my CSC with an oem one before I knew how bad these things are. I then got the RJM clutch pedal which not only vastly improved the clutch feel and consequently the overall driving experience, but it's also said to help save the CSC as it does not extend the CSC as far as the stock clutch pedal does, therefore not wearing it out as quickly.
When I need to get the clutch replaced, I may go with this one (and was thinking about going Southbend lightweight plus quiet disk):
ZSpeed Performance Nissan Infinti OEM & Performance Parts
Very similar thread here: https://www.myg37.com/forums/g37-cou...l-upgrade.html
Did you get the Southbend lightweight flywheel? And did you get the "quiet disk"?
Have not given this much thought nor have I done the slightest research yet. I have heard good things about the JWT combo as well as Z1's. I personally ran Exedy many many many moons ago in my GS-T and absolutely loved it! I know a few local guys here who run Exedy in their boosted 370's and love them.
Currently just have too much going on that places this mod wayyyy on the back burner. But in for more feedback and suggestions
Calg37USMC (02-16-2018)
steez
12
03-08-2016 01:45 PM
DanMardik
17
01-24-2015 06:33 PM
kstampy
26
04-09-2013 04:46 AM
Dough1397
08-16-2012 11:06 PM
