Notices
Does anyone have these tail lights installed?
Old 10-10-2017, 10:12 PM
djdiskino
djdiskino's Avatar
Originally Posted by saywat?
reminds me of my glass top stove
My wife laughed at that 😂 now that I think of it thinking the same thing. Although I don’t know why but my remote start made them do that little light-dance in the beginning, that is not a feature for anyone interested lol
Old 10-11-2017, 11:11 AM
zer099
zer099's Avatar
djdiskino; awesome work. Would you consider making a DIY thread or at least pointers for those of us who might want to try this? Second question: would you mind sharing what brand and type halo rings you used? No worries if its no to either, but never hurts to ask.
Old 10-11-2017, 07:55 PM
djdiskino
djdiskino's Avatar
Sure, I used a dremel to cut along the seem before the lens of the tail light. I used small cut off wheels (several of them) I mastered the depth that the wheel can go into the plastic. I used a box cutter to clean up the scraps.
Attachment 178087
Here the lights is fully cut open and the plastic removed and the led array removed.
Attachment 178086
After this it’s off to drill holes for wires, prep, paint, epoxy the halos from (diode dynamics) and then to seal back up I used clear silicone adhesive.
The following 2 users liked this post by djdiskino:
qmantran (10-11-2017), zer099 (10-12-2017)
Old 10-12-2017, 12:48 PM
zer099
zer099's Avatar
Awesome. Thank you so much. Couple more questions, to clarify. Did you wire in a set of dual intensity circuits to get the different levels of brightness? Also, off hand, what size rings did you end up using? "I used a dremel to cut along the seem before the lens of the tail light." Do you mean you cut the lens before the case, the case before the lens, or right on the seam? Sorry, trying to get a good idea of the best line of attack. Also, the attachments are not working (at least not for me). Again, I don't expect an answer, but it never hurts.
Old 10-12-2017, 04:27 PM
djdiskino
djdiskino's Avatar
The high/low intensities are built into the drivers for the halos. I believe mine were 110 and 90mm. I cut along the seam where the plastic is welded together closest to the lens. I’ll see if I can post these to my Instagram instead since I’m mobile most of the day and this app doesn’t seem to work quite right with the site.
zer099 (10-12-2017)
Old 10-15-2017, 12:26 AM
djdiskino
djdiskino's Avatar
I made a new Instagram if you want to follow my work @whitey_vq - also here is a video I took today to show off the tails better.
View this post on Instagram
Old 03-10-2019, 10:21 AM
qmantran
qmantran's Avatar
So I ended up winning these similar style taillights in a raffle for $150.
Mine are red & amber switchback.
Decided to throw a smoked tint film on it
Factory oem lights with bluebat gtr cutout overlay. The new taillights still utilize the factory led dots for brake lights
Parking light mode lights up red rings
Amber turn signal rings
Old 03-11-2019, 01:48 PM
hdk703
hdk703's Avatar
Does anyone have these? I was definitely contemplating these but one of the reviews kinda scared me a bit, water leaking in?
https://www.ebay.com/itm/DEPO-JDM-Bl...5.c10#viTabs_0
Old 03-12-2019, 03:26 PM
qmantran
qmantran's Avatar
not bad looking for the coupe. They look like they will go well with the oemassive headlights
