2010 G37x Vibration at Highway Speeds
I have a 2010 G37x with about 65,000 miles. It has stock 17" wheels and fairly good tires. Over the last few months, I have been experiencing a significant vibration at speeds over 40 mph. Since I can feel it in the steering wheel, I am assuming it is something in the front end. Also, I am almost positive it is something on the passenger side because when I turn to the left, I can hear and feel the vibration a lot more. Originally, I thought it was a wheel out of balance, so I took it to a tire shop and they informed me that my front passenger side rim was bent. I bought a new rim and had the same shop put it on for me, but unfortunately the problem persisted. I then thought it might be the tire, so I swapped the front and rear wheels, but the problem remained exactly the same.
It doesn't seem like it is a bad wheel bearing because I haven't heard any grinding and with it being such low mileage, I would be very surprised if a hub already needed replaced.
I have read through a lot of the threads about similar issues on here, but it seems that most of them ended up being related to tires, but (assuming the tire shop knew what the were doing) my case seems to be something else. Any suggestions would be greatly appreciated. Thanks!
Have you checked your rotors? Slight chance, but when i had my steering wheel shaking at highway speeds, pedals shaking(usually when braking), the cause was a wrapped rotors, problem was fixed after resurfacing them. Hope you find whatever it is that's causing those issues if that's not the answer.
Do you think there is any chance I have a bent axel or something like that?
Thanks for the help!
While you're there make sure none of the calipers are sticking/dragging.
I have the same problem. Steering wheel will vibrate left to right at highway speeds, around 120kph.
Do you find your shaking is persistent ? For me it sometimes won't do it at 120 and sometimes it will moderately to violently. Weirdest thing I've ever come across. Also just got stoptech rotors and HPS pads and no help.
I noticed you said its worse with left turns... Does it seem better with right turns?? Maybe the wheel bearing or poss axle..
I found the solution to the problem! It ended up being a wheel bearing. I took it into the Infiniti dealer to get the wheels balanced (which didn't fix the problem, obviously) and had them look into what else may be causing the vibration. They said it was definitely a wheel bearing and quoted me around $620 to get the hub assembly replaced. Originally, I had planned on replacing it myself, but I decided against it since I really didn't really have the time and I needed it fixed by this weekend. I ended up taking it into a shop near my house and they replaced the hub for around $440.
Easy way to check for bad wheel bearings.... Jack the car up and get the tire up off the ground. When the tire is in the air, put your hands on top of the tire on the tread directly in line between the hub and the top of the wheel well. Now push and pull the tire inward and outward. The wheel should not move at all. If there is any play back and forth, even a couple of mm or so, that indicates that the bearing is worn out.
NealP (09-13-2017)
Glad you got it fixed, mileage definitely isn't insanely low for bearings to go on this cars. My 2012 X had the front right one go at 74km or ~50k miles.
