Highest Mileage
Old 09-22-2018, 06:05 PM
  #31
Gerardo Pena
Gerardo Pena's Avatar
Thank you for your reply it has all it's service record's up-to-date with a clean car fax so with that being said any idea what a well kept g37 can go mile wise?
Old 09-22-2018, 08:36 PM
  #32
ezbme
ezbme's Avatar
I would think 250k at least. There is the problem with the rear seal which has happened to people with cars from 2008-2010. There is the automatic transmission which can be week. Last couple of days I haven't liked how mine has felt at times. There is the fact that Infiniti used Plastic Valve Covers. My BMW had a plastic valve covers, around 100k I had the gasket replaced, it was only $200 if I remember right.
After about 215k on my BMW my Valve Cover had a small crack by then my car had so many issues and was worth so little I say bye to it.. Damn it used to be that every car had Metal valve covers, wtf. I almost bought a Lexus is350 and they have aluminum valve covers. I had an oil and they told me they saw some oil seepage, I don't think I have lost an ounce of oil. I have them put in Semi-Syn and it is done between 4-5k
Keep up with your fluids. My car has 182,600 on it. I did things that I know were too early. I put in a new battery, but I think that the old one drained by me not switching the car to off one day at work. I saw the dreaded rear diff stain and had a mechanic put in poly diff bushings (for some reason Nissan only puts one in the car, when lexus uses two.), Mobil 1 LSD Diff Fluid and Subframe sleeves, only to find out that my subframe was replaced under warranty in late 2013 and didn't need to have any bushings replaced. I have cleaned my throttle bodies once, but didn't take them off. I figure I will do that when I need to replace the spark plugs which I plan to do at 200k, the last time it was done is 120k.
I bought new front rotors,pads, and fluid on sale. When my mechanic took the old pads out, they had at least 40% life left. One bad thing about the BBK is that it is much harder to tell when the pads need replacement. The rears were done by the dealer before I bought the car.I have had the car since 158k, every fluid has been replaced except for the Power Steering. The transmission flush was done twice because I didn't like that they used something other than Nissan Matic S.
My plan is to get a Tesla Model 3 around 2020 or so, I am looking for one with long dist battery, perhaps only the one engine and upgraded interior. I figure around 2020-2021 they will go for about 20-25, vs say 50 now. I don't care about the audio because I might just get the aftermarket kit made for the Tesla, heard its t!ts.
If I keep my house I will probably get solar panels and a battery so that I can charge it at night. I don't drive more then 150 miles at a time.
Old 09-22-2018, 09:01 PM
  #33
monstur
monstur's Avatar
2012 g37, had about 69k
Old 12-07-2018, 01:10 AM
  #34
AbeG37vq
AbeG37vq's Avatar
2012 Infiniti G37 112k, water pump replaced along with coolant, Mobil 1 synthetic oil changes around 5.5 - 6k. Changed transmission fluid every 30-35k. Changed differential fluid every 40k.Very reliable car and I plan on keeping it until the wheels fall off (that's what I say now).
Old 12-07-2018, 07:04 PM
  #35
antirice
antirice's Avatar
Was there issue with the water pump?
Old 12-10-2018, 10:46 PM
  #36
LDG
LDG's Avatar
Originally Posted by fennsta_78
What kind of mileage does everyone have on their cars? Can you get 250K out of these cars?
I have a 2009 G37X with 135K.
Ive got a bone-stock G37 6MT with 230k. It’s my daily driver.
The following 2 users liked this post by LDG:
Eddie Ex (06-25-2021), user 83499 (02-09-2020)
Old 12-16-2018, 05:31 PM
  #37
AbeG37vq
AbeG37vq's Avatar
I don't think it's a common issue on the G37 for the water pump to fail. Mine just happened to failed at 112k. What happened was that I noticed a wet drip from the driver side on the engine when I was doing a brake job. Took the car in to the dealership and they pressured tested the cooling system and it turned out to be the water pump.
Old 12-16-2018, 05:32 PM
  #38
AbeG37vq
AbeG37vq's Avatar
Is there anything we should look after as the mileage creeps up?
Old 12-16-2018, 10:55 PM
  #39
pri.g
pri.g's Avatar
Any issues with the clutch slave cylinder failing?
Old 01-24-2020, 01:23 PM
  #40
Joey Blacklidge
Joey Blacklidge's Avatar
Just hit 254K in my 2009 G37 sedan. I changed the plugs and coolant at 100K. Just routine oil changes since then
Old 01-24-2020, 01:25 PM
  #41
Joey Blacklidge
my 2009 G37 just hit 254K
Old 01-24-2020, 04:48 PM
  #42
Selym
Selym's Avatar
Kilometers or miles?
Old 02-22-2020, 10:59 AM
  #43
CalvinHunt99
CalvinHunt99's Avatar
I actually had the same question as you, and when I researched online, saw a ton of people that said they hit over 200K up to 250K without any issues as long as they maintained the car. But I just purchased mine less than a week ago, it's at 59K miles. *Got it for $12K (before dealer fees and my added warranty). Loving it so far!
Old 03-10-2020, 04:01 AM
  #44
Cristy Dean
Cristy Dean's Avatar
Talking 130 and gooooing
2013 w/ 130,000. Drives AMAZINGLY and have not had a single issue (other than a battery replacement) KNOCK ON WOOOOOOD
Hiowatha88
Buying & Leasing
09-26-2019 03:23 PM
bmmerm
09-15-2019 07:33 AM
MeMrS
Buying & Leasing
03-17-2014 06:42 AM
Quick Reply: Highest Mileage
