Notices
Flickering
Old 05-23-2017, 09:35 PM
zonnie
zonnie's Avatar
Flickering
driver side headlight bulb works intermittently. i thought the bulb was burnt but upon driving today it came back on.
when i turn the low beam on and off the driver side bulb flickers and just turns off most of the time. If i turn it on and off many many times ie. 10+ times then sometimes by luck the bulb will light up again.
is the bulb the culprit or the ballast?
can bulbs be "partially burnt"?
Old 05-23-2017, 10:11 PM
Epiphany
Epiphany's Avatar
Could be bulb or ballast. If you want to check you can switch the driver and passenger bulbs and see if the issue follows the bulb or not.
Old 05-24-2017, 11:56 AM
monytx
monytx's Avatar
Have you upgraded your HID bulb as of late? The ballast on the G is very picky with bulbs. I went through several sets of HID bulbs before I got the right ones. Try what Epiphany stated above if that doesn't work you might have to try new bulbs.
Old 05-24-2017, 02:12 PM
zonnie
zonnie's Avatar
Nope, but I just ordered d2s to swap both of them.
I hope its the bulbs no the ballast..
Old 05-24-2017, 03:37 PM
staskz
staskz's Avatar
I have this problem. my headlights are upgraded with diode dynamics bulbs, its become very annoying lately.
Old 05-24-2017, 03:57 PM
zonnie
zonnie's Avatar
my bulbs are OEM currently with the issue..
Old 05-25-2017, 01:49 PM
Diode Dynamics
Diode Dynamics's Avatar
Please contact us, we would be happy to take care of that for you: (314) 205-3033
We want to make sure you are happy
Nick C.
Old 05-26-2017, 01:21 PM
zonnie
zonnie's Avatar
Yup it was the stupid ballast.
