Bilstein B16 (PSS10) coilover suspension available soon for sedans!
Old 04-15-2017, 09:46 AM
  #31
transportchef
transportchef's Avatar
Sorry 4DRZ I am tipping around in South Jersey 4Drz. I am confined to the eastern seaboard. If you are out this way will be happy to oblige.
Old 04-15-2017, 12:48 PM
  #32
4DRZ
4DRZ's Avatar
You haven't looked at the Sedan Coil-over list in the Brakes and Suspension forum?
Not sure what you mean here. If you are talking about a list of coil-overs that people have put on their sedans- great, I could list my Teins as well. I was initially excited about the PSS10's being listed on Tire Rack because they specify between the coupe and sedan. It turned out these have the same part number for the 370Z so they are not specially tuned for the excess weight of the sedan like I originally thought.
Never been to south Jersey. Although I am thinking pretty seriously about some Carbon Fiber Element work on my silver interior trim and I think they are in Jersey. I would probably mail it to them though. My sister lives near Boston, but that would probably still be a pretty big drive.
Old 04-15-2017, 10:13 PM
  #33
slartibartfast
slartibartfast's Avatar
https://www.myg37.com/forums/brakes-...ers-redux.html
Old 04-17-2017, 12:34 PM
  #34
4DRZ
4DRZ's Avatar
So this is a list of coilovers that can fit the sedan that you created. If you want to add the spring rates for the PSS10's, I have them listed in post #20.
Old 04-17-2017, 04:20 PM
  #35
slartibartfast
Added. Thanks for the info.
Old 04-19-2017, 10:52 AM
  #36
transportchef
Best of luck to you 4DRZ. Offer still stands
Old 04-20-2017, 02:34 PM
  #37
4DRZ
4DRZ's Avatar
Thanks man! If I am ever out that way, I will try to remember to look you up. But for now would you say the PSS10's make the car a little bouncier than stock over 45-50mph roads that look new, but have bad seams so every car bounces a bit?
Old 04-20-2017, 07:37 PM
  #38
transportchef
I wouldn't go that far. It just should not be there. Its more like you can feel a subtle subdued bounciness. like waves
I think if they had went with a beefier spring I wouldn't be complaining.
Old 04-21-2017, 10:27 AM
  #39
4DRZ
4DRZ's Avatar
So the PSS10's are bouncier than stock or smoother on these types of roads?
Old 04-21-2017, 09:01 PM
  #40
Received 4,940 Likes on 4,174 Posts
Did you consider the spring extenders from KW so you can ride a bit higher but keep that KW ride that you're happy with?
Old 04-23-2017, 08:52 PM
  #41
transportchef
4DRZ they are better than stock and smoother. Its just that I noticed the lights had some bounce to it. It is better than stock by far. I just did not remember any of that with the Kw3.
blnewt I did consider and inquired about the extenders. They said that it would void warranty if used. Because it put them outside tested range. I didn't want to chance it.
Old 04-24-2017, 12:12 PM
  #42
4DRZ
4DRZ's Avatar
Well, that is awesome news that the PSS10's ride better than stock- that is a 1st that coilovers ride better than a stock suspension. My Tein's definitely do not ride better than stock, but they are very close to stock.
Sucks to hear about the low ride height though.
Old 05-20-2017, 12:06 AM
  #43
jcho01
jcho01's Avatar
Also bought mine from Tirerack in January. I have the PSS10s on my 12 G37S Sedan RWD. The ride is smoother than stock with all seasons compared to stock.
This is because I had swapped out the Potenza S04s to Michelin A/S 3+. Thinking that I could get away with just installing the coilovers, I learned the hard way after the tires started wearing from the inside. Installed SPC FUCA and Voodoo13 Rear Camber. Did not need Toe Bolts.
Mind you that it takes a few hundred miles to have the coils break in. I took it for an alignment and it was fine.
I have at exactly at the middle on the dial ***** and as for the ride height too. These are adjustable dampers on a scale of 1 to 10.
The ride quality is smooth. Watch out for driveways, potholes, dips, speed bumps, and inclined hills; my undertray is done, and the midpipe keeps bottoming out.
Old 05-20-2017, 10:48 AM
  #44
4DRZ
4DRZ's Avatar
Glad to hear you like the ride. I am impressed that a coilover can ride smoother than stock. Does your car seem to ride low in back like some people have talked about. I wonder about the performance of these on track compared to the Tein basis I have now.
Old 05-21-2017, 11:57 PM
  #45
jcho01
jcho01's Avatar
It seems to ride low in the back. There seems to be more drop in the rear than in the front.
