Sedan weight reduction
#31
Well, that's true. Moving the battery shifts the front-2-back weight distribution delta by twice the battery weight. Fair point.
The rest... IDK. I suppose if you do it and the change is perceived negatively, you swap back in a few minutes, and are only out the time and materials to make the project happen.
#32
Have you had a chance to corner weight the car? I wonder how exactly the car is balanced, wet weight with all fluids and no driver. And how someone in the driver seat is distributed on the corners.
For the benefit of many of us here, also how a passenger's weight will be distributed (driving instructor @AutoX or HPDE, for example).
For F/R balance, I'm putting all the 370Z bracing in, which adds like 35 pounds to the rear and about 7 pounds to the front.
Those of us with oil coolers in the front, will also have to take that into consideration.
Leaving the OEM rear mufflers in will also help the balance, as will the spare tires and such. (I'm doing exactly this, modding all the pipes between the cat and the mufflers.)
HFCs are also a bit lighter (and will yield more weight savings than a battery). Good weight off the front for that 50/50.
You have an interesting project going on, 4DRZ. I like it
#33
Good points p0on. I have an oil cooler hanging off the front of the car too (probably the first mod you should do if you plan on tracking the car), but it does not add too much weight.
I never thought about saving weight with the HFC's so I probably lost a little weight there. Probably also lost some weight with the headers.
If I don't have any luck finding a lighter battery and start thinking seriously about relocating the battery to the trunk I will probably corner weigh the car first. I have some racing friends with scales who only live an hour or so away, so not a big deal. Sometimes, they even bring them to track days.
I feel like I should have gotten a base weight on the car before all the mods, but I still have some of the stock parts so it should not be too tough to start figuring out most of the weight savings.
#34
I have an Odyssey PC680MJT in my car now and it works great. 15.4 lbs
You can use the stock mount if you put a small piece of wood under the batter to raise it some. I also bought a new J hook from O'Reilly's because the batter still sat lower than OEM.
I plan on installing an Odyssey batter holder this week so it holds it down a bit better. About $100 for the battery and about $100 for their aluminum hold down.
#36
The other option is to use the Odyssey hold down. I used the OEM battery tray in combination with their brackets. This really does hold down the battery much better.
The OEM battery tray is a mixture of plastic and metal so it is pretty light. I drilled two holes through the center metal piece and the other two holes are just through the plastic.
You have to install the battery tray with the Odyssey side brackets prior to adding the battery because one bolt in the battery tray is blocked by the battery.
SupraOfDoom (02-28-2020)
#37
That's pretty cool, jgronline. Well done.
#39
WEIGHT LOSS SO FAR:
Tein Basis: 10.6 lbs
TSW Interlagos w/ RE-71R's: 8 lbs
DC Headers: 7.8 lbs
Stillen Pulley: 4 lbs
Total: 30.4 lbs
I think I may have also lost some weight with the Z1 high flow cats and maybe the Stillen exhaust and Z1 cold air intakes. Doubtful on the Hotchkis sway bars. I forgot to weigh all these parts before I installed them. If anyone has weights of these parts vs. the stock parts, please post them up.
I am also in the process of looking for seats which should save the most weight of anything so far. (I have another thread in the sedan section on this)
I also plan on getting the Z1 2pc. front rotors at some point which shave off another 10lbs. each.
I thought a lighter battery would be a cheap and easy option, but I am struggling to find one that has enough cold cranking amps for our cold WI winters that does not cost a fortune. If anyone knows of any with the same or more CCA than the factory battery that does not cost a fortune, please let me know.
DC Headers: 7.8 lbs
Total: 30.4 lbs
#40
I've heard seats are like 70lb each, not sure if its accurate but it would make very significant weight reduction. Also I read some older posts about how great car feels after upgrading drive shaft to carbon fiber / aluminum, couldn't find drive shafts for AWD models? pretty sure someone out there makes them or can be made.
#41
WEIGHT LOSS SO FAR:
DC Headers: 7.8 lbs
Total: 30.4 lbs
DC Headers: 7.8 lbs
Total: 30.4 lbs
#45
I looked into alum/carbon driveshafts, but I only see them for the coupe. If you see one for the sedan, please let me know.
Really?!? Wow, that would save some weight too. Does anyone have the weights for stock vs. Z1 high flow cats? How about stock vs. Stillen cat back or stock vs. Hotchkis sways? I will update this thread with the weights when I get them.
