The Sedan Exhaust Thread
#1591
I got my RHFC's installed a few weeks ago and just started noticing a subtle rattle coming from that area. https://youtu.be/oHRVfpmU5Ko
I don't hear a "marble-in-a-can" noise when banging on them a bit, and there's no difference in performance either, but when I was under there I also noticed this:
There's a chip with exposed material, which probably came from a rock, but the cracks along the ridge worry me most. I was planning on getting a brace welded next oil change after the install shop expressed their concerns. Could this be the result of too much play due to the lack of a support brace?
#1592
#1593
#1594
For context, here's an old pic of my Fast Intentions RHFC when new back in 2014.
Now I'm no design engineer, but this looks pretty damn good to me.
Hey, obsidiansamurai, there's a FI logo on your cats. So you got that going for you.
#1595
How does mild steel flanges holding up in Rochester winters?
#1596
Ha, it's the little things in life. Too bad the logo will go away when I put the Berks back on.
#1597
Not great. It would be worse if I drove it more in the Winter, I'm sure. Flanges are gross and rusty, but the pipes are pristine. Flange bolts are also fine, but I had the foresight years ago to replace them with SS hardware.
#1598
This is what stopped me from buying FI cats, went with BERKS again. Dont like cheap mild steel flanges, after few years in Chicago winters, not much will be left of them....
#1599
The Berks sounded great but had this tinge of rasp from 3.5-5k, something I was never able to quell. I always wondered if wrapping the Berks in something would help, which I could easily do now that they're sitting in the garage.
#1600
With the mild steel flanges and lack of support brace, I'm surprised more people haven't had issues with these things.
Honestly, I'm a bit hesitant to put another set back on. The Berks sounded great but had this tinge of rasp from 3.5-5k, something I was never able to quell. I always wondered if wrapping the Berks in something would help, which I could easily do now that they're sitting in the garage.
#1601
Don't like X pipes, losing power on that one, y pipe is the way to go. Resonators should be as close as possible to cats, not sure where your Vibrants installed and what kind, but when I installed ULTRA QUIET Resonator it killed most of the rasp...
#1604
obsidiansamurai (04-28-2019)
