Notices
Window Roll Down Issue
Old 03-24-2016, 09:23 AM
jmadey23
jmadey23's Avatar
Hey Everyone,
I've got a 2011 G37x and the other day I got in the car before work, went to roll down my windows (all windows have auto up/down) only to find that the only window that will do anything is the driver side window but auto up/down seems to be disabled, the rest of the windows won't budge, and the sun roof still works as it should...
Very bizarre.
I've tried all sorts of resets and suggestions I've found on this forum but now at the point that I'm going to need to take it somewhere.
Anyone ever see this?
Thanks very much.
Old 03-24-2016, 10:23 AM
ANMVQ
ANMVQ's Avatar
So you did the hold UP for 5 seconds window has to be all the way up, (each window) the the hold down for 5 sec, with window all the way down?
Old 03-24-2016, 11:40 AM
jmadey23
jmadey23's Avatar
Yes sir, no luck.
I also noticed that my key fob works to unlock/lock doors but the horn "notification" (the beep after I hit the button) doesn't sound off.
Nothing odd has happened lately. Parked my car one night and it all worked, woke up the next and it just stopped.
Thank you.
Old 03-24-2016, 11:50 AM
ANMVQ
ANMVQ's Avatar
odd thing but maybe the car battery is starting to go, also can you roll the windows down by just holding down the unlock on the key fob and roll them up using the key in the drivers door( outside LOL) turning it to lock and holding it there?
Old 03-24-2016, 12:53 PM
IracknBack
IracknBack's Avatar
Is that a feature these cars have?
Definitely trying this when I get off work.
Old 03-24-2016, 01:09 PM
jmadey23
jmadey23's Avatar
I've been thinking I may need to replace my battery.
This is great, I'm going to get this taken care of ASAP and hopefully it resolves the issues.
Thank you!
Old 03-24-2016, 02:17 PM
HoldmyMouse
HoldmyMouse's Avatar
Did you press the button that disables the windows? It's the button right by the door lock. I usually do that after I wash my car so I don't get water streak if I accidentally roll the windows down.
Old 03-24-2016, 02:21 PM
kickintheglass
kickintheglass's Avatar
Did you try hold down both the lock and unlock button at the same time? This disables/enables the horn when you lock the car.
Old 03-24-2016, 03:07 PM
seeblackrain
seeblackrain's Avatar
Did you try this reset method?
Have all windows rolled up. Start with one window and roll down halfway. Then pull UP and hold for 4-6 seconds. Repeat for other windows.
But usually when you unhook the battery or something along those lines, it resets and disables the AUTO up/down feature and you have to manually set it up.
Old 03-24-2016, 03:59 PM
jmadey23
jmadey23's Avatar
This.
I'm wondering if my battery isn't waning and reached a certain point...and I left my interior lights on overnight recently...
You guys are all awesome, this has all been so helpful.
jacob sami
04-11-2016 07:24 PM
shane7352
General Tech Questions
03-24-2016 02:20 PM
Gatson1983
03-22-2016 07:38 PM
kenbulmer
03-12-2016 05:36 PM
Upscale Speed
03-02-2016 04:25 PM
Quick Reply: Window Roll Down Issue
