Differential Fluid, Auto Trans Fluid Change Timing
Old 09-17-2015, 10:45 AM
ryang37x
ryang37x's Avatar
Hey all,
I have an appointment at Infiniti for an oil change and tire rotation and was wondering when you all changed your diff fluid? My car has 41k miles and as far as I know it hasn't been changed. Too early to change? What about trans fluid and power steering? I was thinking of waiting til 60k to change all 3?
thanks!
Ryan
Old 09-17-2015, 10:47 AM
blazeplacid
blazeplacid's Avatar
I did mine at .....
Diff service - 60k
Power steering - 100k
Auto or manual trans? Auto - dealer said 100k...manual...im not sure
Old 09-17-2015, 11:12 AM
Gio37
Gio37's Avatar
Changed Diff & Trans(mt) fluid a couple of weeks ago at 60K miles
Pretty easy to do. Just get a hand transfer pump and you should be all set to go.
g/l
Old 09-17-2015, 04:48 PM
guy from norcal
guy from norcal's Avatar
Just did my diff last weekend at 49,000
Trans is next (7AT )
Old 09-17-2015, 06:22 PM
Received 4,940 Likes on 4,174 Posts
g/l
ATF change is a bit more involved than the 6MT, but not too bad
https://www.myg37.com/forums/d-i-y-i...rop-clean.html
Old 09-17-2015, 06:48 PM
Ricio1991
Ricio1991's Avatar
I did my rwd differential fluid change at 30k
Old 09-17-2015, 07:07 PM
Falker11
Falker11's Avatar
Plan on changing my diff and trans fluids (MT) in about 1500 miles - at 30k
If I didn't DIY i would probably wait longer
Old 09-18-2015, 02:49 PM
Victory
Victory's Avatar
Ive got precisely the same milage and just asked this over in the tech section.
Since I DIY, I'm going to do the differential next time im under there to do my oil. AT seeems good for a long time, so im not going to worry about it to at least 60-80k
One thing i didn't get an answer to was whether i need to worry aboit the front diff and transfer case. As the ATTESA is primarily RWD, am I correct in assuming they dont get nearly as much wear, or should i change them as well?
Old 09-22-2015, 05:33 AM
takeapieandrun
takeapieandrun's Avatar
I bought my car in '13 with 72K miles, and I promptly got the 75K service done to clear any doubts out of the way. The ATF was pretty dark and clearly a bit overdue so I went ahead and had that done. I'm not sure it was changed before that, as the only previous record of the car's service at the dealership was at 15K miles. I didn't notice any difference after the change, a good thing I guess. Oh, and I have the 5AT.
superjoey
31
03-22-2023 11:56 PM
Thedbarz
33
02-09-2016 12:05 AM
zero260
08-12-2015 10:02 AM
Corvalis
08-06-2015 04:36 PM
Quick Reply: Differential Fluid, Auto Trans Fluid Change Timing
