MyG37
MyG37 (https://www.myg37.com/forums/)
-   G37 Sedan (https://www.myg37.com/forums/g37-sedan-348/)
-   -   Car wouldn't start, red car and key flashing (https://www.myg37.com/forums/g37-sedan/269066-car-wouldnt-start-red-car-and-key-flashing.html)
si_driver Jul 26, 2015 08:25 PM
Just had a strange problem. I needed to mount a dash cam in the car, so I opened the door with the fob, opened the passenger side door got it. I need power for the dash cam so I pressed the start button once. I am in there for about 3 or 4 minutes with the radio playing. I get out and try to lock the car with the fob, nothing happens..
I got into the car and tried to start it, nothing, I put the fob into that slot, nothing, got the second fob, nothing, radio still playing, but nothing else is working, can't lock doors manually, can't open windows, absolutely nothing other than the radio is working.. Quick google search indicates a possible tow to the dealership.. GREAT!!!..
Last resort, I unpluged the battery for 2 minutes. Car is working again.
Anyone else run into this issue before. not sure I want to try to duplicate the scenario ....
BTW, 2012 G37xS with 48,000 miles.
takeapieandrun Jul 27, 2015 02:01 AM
I have. My car locked up on me after changing the headlights (I had them on for maybe 2 minutes to check they worked). I panicked and thought my ECU was fried.. on top of that the alarm was going off because my locks wouldn't work and I had to reach in through the window to unlock the car manually. I disconnected it over night, and got a jump from my dad and started up fine. Realized it was ultimately a bad battery. Got a Duralast gold and haven't had the problem again..
I'm guessing our cars freak out when the voltage from the battery dips a bit low. After the first time, it never does it again and just refuses to start if it gets low enough.
VIVID Jul 27, 2015 11:35 AM
+1 On that experience due to a bad battery.
Took a while to figure out because a new battery was installed to correct the problem (Bad Cell). Turns out the new battery came from same lot of batteries as the previous one...it was a bad cell again. But before that: the dealer was chasing wiring/draw issues...dealer finally figured out the batteries came from same lot and got another (#3) from a different lot of batteries. I have never looked back.
Sean
si_driver Jul 27, 2015 12:05 PM
Kind of would makes sense, but my car started working correctly and started just fine after I unplugged the battery for a minute - same battery.
takeapieandrun Jul 27, 2015 04:42 PM
Mine discharged over night to the point it wouldn't even crank after giving me no problems for the previous 2 years. But I think that initial voltage drop from a weakening battery is what makes the car go bonkers while in acc or on mode, I don't think it replicates it again if you're just trying to start up the car. I ran with the same battery for a week after and had to get jumps once in a while but for the most part it was good.
VeXeD Jul 27, 2015 06:32 PM
Immobilizer system? ECU doesn't recognize key
Common maxima problem
© 2026 MH Sub I, LLC dba Internet Brands
