Hotchkis Sway bars install - Need new end links?
Going to install a set of Hotchkis sway bars on 09 37X sedan this weekend. I would appreciate any opinion/experience in reference to the endlinks.
Should I plan on replacing them or upgrading them? Keep in my in live in Western NY with lots of salt and rust, will they get damaged during removal? Does upgrading them provide additional performance enhancement?
Thank you
Thank you
I did my sways last summer, like anything else with time all things rust. But to get life out of them I recommend spraying the salt off as much as possible and keep things lubed when possible during the winter. As far as the endlinks, I think the only ones available so far for the x sedans are the rears. I installed the white lines, as long as your careful you shouldn't have any worry damaging them. Simple bolt to get off.You don't have to upgrade right away, but these aftermarket are much stronger and adjustable. Depends on what setting and how hard you plan on driving. I didn't want to have to do the job twice so I upgraded for the stronger endlinks. overall you do notice the sways improve the handling and roll. Hope this helps.
I've had mine for years with OEM end links and I've been fine. No track days but a lot of spirited driving. I am experiencing some front suspension squeak, and I think I've narrowed it down to the bushings for the hotchkis. Chicago winters are rough. But a rebuild kit is pretty cheap. Less than $40 I think. You'll love the way the car handles with them. I have a 2010 xS sedan.
If you want adjustable end links, then the only option for AWD is the rear (since they're essentially the same as the RWD)
Adjustable ones should only be needed if you're lowered though.
If you just want more stout end links, perhaps Moog is the way to go. I bought a complete set of Moog End Links for my AWD. I haven't actually installed them yet, but perhaps I can get to it this Spring.
I made a thread about it a couple of months ago if you want to search.
portagepaws (04-12-2015)
I also have a pair of Hotchkis sway bars on my sedan with OEM end links. No problems for me.
The only thing I hear are the squeaking noises that come from the front end bushings. IMO, the Hotchkis bracket zerk grease fittings are useless. It's impossible to squeeze a good amount of grease in there when everything is bolted down and tight. I have learned that the best way is to remove these from the car, clean up the debris, and generously regrease it by hand. It takes a little more time but definitely worth it.
Some OEM end links will break with stiffer sway bars, some won't. YMMV. My rear links broke on both sides. Most people's don't. The setting you have them on, how you drive, and how lowered your car is all play a factor. Do you absolutely need new aftermarket end links? No. Not unless yours break.
From what I've read, the relevant modification to wearing out end-links isn't the aftermarket sways, it's lowering the car. Since I've done both, I was in the same boat... replace the end-links now, or later?
In the end, I took my mechanic's advice, and decided to wait until it becomes a problem, if it becomes a problem.
The following 2 users liked this post by Rochester:
ocie (01-08-2016),
Thanks for input everyone, much appreciated. Hopefully the stock ends will come off without issue and I will use them. Very excited to install the sway bars, or should I say drive with them!
Installed them today, skip to the good part... WOW WHAT A RIDE. Amazing difference! Details part, the stock end links work just fine as everyone mentioned. No issues installing them just follow instructions and reference the DYI's people gratefully posted. Haven't been this excited to go to work and hit the 390 on-ramp tomorrow!
Thread reopened
Arrives in a week - im excited like a lil kid - can’t wait till it’s installed
The transformation part
Vegas has a lot of good highway entrances & long
Straight away & lots of corners with no one around
Can’t wait 😊 lol
You will probably be ok with stock end links on the street. Mine finally gave up on the track and they got really loud. I replaced them with Moog end links and they were fine the last few track days. If you ever need to upgrade the end links, the Moog end links are decent and have their own zerk fittings so they are easy to grease when you do the sway bar bushings.
You should have zerk fittings on the bushings for the sway bars. They probably just dried out. Use a good waterproof grease like marine grease that should be available at most auto parts stores.
Kpmikey808 (12-23-2017)
