Adjust driver's door
The driver side door seems to sit a little low when closing. For instance, if I close the door slowly, I can feel that it hits the latch bar and lifts before latching. All other doors do not do this. I can let those doors go about 12" from close and they close solidly. I think most would not even notice...but it bugs the hell out of me. How do I adjust that?
Are you the original owner? On some vehicles like p/u trucks and large SUVs the driver's tend to use the door to help them exit by hanging on it. This causes the door to sag over time.
I've seen people use 2X4s to lever the door back up into position, something I wouldn't do on a G37. |
Take it to a trusted body shop and see if it's something that can be adjusted. I assume that either you're not the original owner or if you are that you've had some sort of impact that has altered the way it closes. Either way I doubt that the dealer will help you out financially or try to cover it under warranty.
It could be something as simple as replacing the door latch where it may have been hit and is just slightly bent, or it could be that the body shop that fixed the door (assuming it was in an accident) didn't replace the door hinges to try to save a little money and it doesn't close right anymore. I've had the latter happen to me. I got frustrated enough that I ended up selling the car. I'd start by checking the latch to make sure it's not bent. Then visually check the hinges and cross reference the door that isn't closing right with the one on the opposite side and see if you can tell a difference. Then make an assessment from there on whether it's something you think you may be able to fix or just take it to a body shop to have it looked at/fixed. |
My old G35x drivers door sagged a little, very easy DIY fix. Open the door, take a hammer and lightly tap the U-shaped door striker UPWARD. Tap from the bottom up. Use a block of wood between the hammer and striker if you'd like. A couple light to medium TAPS should do the trick. Tap a few times, close the door to check alignment and repeat as needed, slightly harder blows as required. 2 minutes and done. You will also notice a change in sound the door makes when closing, it will sound better. Leave the door hinges alone and no need to replace a simply mis-aligned striker.
The striker is the silver U-shaped thing on the B-pillar as shown here: http://pictures.topspeed.com/IMG/cro...-38_600x0w.jpg |
Originally Posted by movinon
(Post 3871794)
Originally Posted by '11G37S
(Post 3871880)
Originally Posted by GAWD
(Post 3871899)
I would take it to body shop and ask them how much they would charge you to tweak the door so it closes properly. My guess would be they would be they would lever the door up just a tad until it is back to normal.
(Post 3872019)
Thanks for the help. |
| All times are GMT -4. The time now is 06:12 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
