Canadian Car DRL Disable
#31
hey awakence what are the odds, I am in vancouver too but I do not know any infiniti techs. Do you think you can help me deactivate the DRL as well? I am willing to pay whatever is reasonable! Many thanks!
#32
To reprogram the BCM you need to find the DRL Disable menu in Consult, and when you select disable it will ask you for a BCM ID, this is where you need to enter the last 5 digits of the American BCM Part #
The reason I suggested to find an American car with the same specs as your car was to ensure that no other BCM functionality would be lost, wouldn't want your car to start doing weird things.
Unfortunately I am not able to toggle the DRLs on or off, I believe I would have to have my friend reprogram my BCM back to my stock Canadian part # to get my DRLs back.
The rationale behind this whole process is to trick Consult into thinking your car is American, my friend tried disabling the DRLs through consult with my stock Canadian BCM part # and it wouldn't go through, likely because Consult wont allow a Canadian car to leave the lot without DRLs by law.
#33
I did this awhile ago so my memory is a big foggy, I believe you need to find the American VIN, and then search the American VIN into the Infiniti parts database and find the BCM # that is associated with that car. The BCM number should be 284B1 XXXXX <--- (this part is specific to the car I believe)
One thing, is it possible if I get a US BCM? Would it be plug n play or would it have issues communicating with the keys?
#35
And if possible, if you have the 2011 G37XS Sedan, could you pm me the BCM you used? I might be able to get a dealership to deactivate mine.
#36
Hey DriveClean, I'm trying this this week. Can you give me a little more detail? So your lowbeams work exactly like normal (running turn signal bulb, parking/sidemarker light, and HIDs), and highbeam of course works as normal, and fog setting turns fogs on? But the only thing affected is that DRLs are now halos that turn off when any other setting is on?
Hope this is more clear....
#38
I got it done without it, it was working before I drove home. Halos and all, and he put a relay with my fog lights so when my fogs turn on (which is always, on the night setting), everything would. But idk why, it's not working anymore so I'll go back tomorrow. But otherwise, halos/demon eye work lol so that's something. Just can't drive at night I guess.
#39
I’m wondering this aswell ^^^
QUOTE=Awakence;4117537]Hey i have a buddy at infiniti and i want to try this. He is asking if he needs any of my bcm info or just an american VIN with the same option/rim as my car. Also since you "disabled" your DRL are you able to toggle it on and off?[/QUOTE]
Lt8Che
91
04-08-2022 04:55 PM
sydnrusty
11-21-2015 10:42 PM
350zrunnin12s
08-09-2015 09:55 PM
