brake fluid reservoir
sticker symbol represents braking sys
rochester is correct in stating the symbol represents the brakes. btw your brake fluid color looks good to me. usually people tend to neglect to service the brake fluid in the braking system but i don't see any harsh discoloration of fluid in the reservoir.
I wonder what the recommendation is on brake and clutch fluid.
I was referring to the clutch reservoir fluid color, not the brake fluid color (hence the snide remark about driving AT). Maybe I'm not seeing it well, but it appears somewhat dark. Iced tea color rather than clear or slightly yellowish. If that's the case you should flush it and refill with fresh fluid. Brake fluid (and the clutch system) should be changed every year to 2 years regardless of mileage depending on how diligent you are with maintenance. Because it absorbs water.
I was actually trying to be helpful in this insurance.
Turns out this was valuable for me, too. I've never focused on brake fluid as a factor of elapsed time, more of just part of an overall brake service when rotors or pads are getting installed. But after this thread came up, I contacted my INFINITI Service Department, and they said their recommendation was to swap fluid if it ever got to where it was over 3 years old. So I'm having that done next month, with my annual inspection. (Good info, BB! Thanks!)
While there, I'll discuss the clutch fluid. I'll tell them some car forum moderator was mocking me for the fluid color... that should be fun.
You're welcome, buddy. Always happy to take and post pictures.
If they tell you it doesn't need attention (which is unlikely if you are going to pay them to service it), ask them since the fluid is the same type as in your brake system why it's a much darker color. The correct answer is that it has taken on the dark color form small bits of sediment from the seal in the master cylinder. If you look closely you can probably see some larger particles on the bottom of the reservoir. If they give you grief, just tell them that Black Betty said so. That usually works.
Quick question about the clutch reservoir. I just changed out some of the fluid and I don't really remember if the cap fits under the tabs... I remember it was kind of hard to take off the cap but I can't figure out how to make the cap fit under the tabs... If it does... -_-
Just say no!!!!!
Sorry to resurrect an old thread...
I did my clutch flush last week (~17K miles, 3 1/2 years). The fluid didn't look too bad. In fact, it was lighter than the brake reservoir fluid which was just changed last november (~3K miles ago).
This got me thinking, when the brake reservoir fluid was done, it was almost clear. Now it looks about as dark as the pic in post #14. I used off the shelf valvoline dot 3/4 fluid:
I realize DOT 4 is a bit more hygroscopic than dot3, but to darken so quickly is discerning. I have no intention of running a race fluid whose shelf life is even shorter. Anyone have any experience with prestone dot 4 or other fluids for street purposes.
@rochester, was your clutch fluid level that low when you checked it or did you suck some out to replace with new fluid?
My point being, clutch fluid was replaced as a part of that repair work.
^ and i'd be willing to bet your dealer used the 'GTR' spec clutch/brake fluid too. mine did when they replaced the CSC under warranty. not that i noticed any difference.
i had done a re+re of clutch fluid about a year before the CSC was replaced, and yes it does get dark and cloudy over time as it absorbs water and clutch dust contaminants. i actually wiped contaminants out of the reservoir - nasty black stuff.
#29
Just say no!!!!!
Rochester, didn't realize you had a failed CSC. That explains the low fluid levels.
Back on the topic of brake fluid, I came across something called Pentosin brake fluids. Apparently it's the OE stuff used in german cars. It's available locally from most places.
http://www.pentosin.net/f_brakefluid.asp
It has better specs than the valvoline or prestone fluids. A little pricier ($14/liter), but may be worth it.
509F dry boiling
329F wet boiling
509F dry boiling
329F wet boiling
Mattimus
10-04-2015 01:33 PM
