Sedan Chat Thread
Old 06-26-2018, 11:39 PM
  #12316
STownSaint
STownSaint's Avatar
Also, someone should grab these (clean IPL wheels/tires for $1000 neg)
https://washingtondc.craigslist.org/...622641817.html
Old 06-27-2018, 12:01 AM
  #12317
Calg37USMC
Calg37USMC's Avatar
If I was still in Quantico I would but shipping would be a killer lol
Old 06-27-2018, 06:22 AM
  #12318
Received 4,571 Likes on 3,422 Posts
So he's Canadian...
Canadian. Kind of wish I were Canadian.
There was a Primary last night, and one of my neighbors won. (I voted for him.) Odds are really good that he'll be going to Washington after November's election to serve in Congress. One of my neighbors... seriously, he lives right down the street from me. Very humble household, very pleasant guy.
That's pretty damn cool.
The following 2 users liked this post by Rochester:
blnewt (06-27-2018), milosz (06-29-2018)
Old 06-27-2018, 06:47 PM
  #12319
2GoRNot2G
2GoRNot2G's Avatar
Hey Guys. I'm moving my company office closer to my house in July so I've been going through my warehouse and have a bunch of sedan parts for sale. If you 're interested I have these parts are listed for sale at the below link. Keep checking back though as I seem to be finding more parts every hour. LOL
https://www.myg37.com/forums/private...-and-more.html
Daddy Fat Sacs (06-28-2018)
Old 06-27-2018, 06:57 PM
  #12320
2GoRNot2G
2GoRNot2G's Avatar
And now that I'm attuned to it, I'm hearing the bearing chatter (if that's what it is) all the time when I'm in a position to listen. Like in the garage, or next to another car in a parking lot.
Yep. This is going to drive me freaking nuts. I can feel it burrowing under my skin, making me cringe just thinking about it.
Sounds like the throw-out bearing might be going, John. Does the noise go away or change when you hold the clutch in?
Old 06-27-2018, 08:22 PM
  #12321
Exactly. Chatter goes away as soon as I push the clutch pedal, and comes right back if letting out the pedal while in neutral. However, I don't hear the noise when releasing the clutch pedal into 1st gear, even when doing it as gently as possible, but that's hard to tell because the engine/exhaust is somewhat loud.
Planning on getting a mechanic's analysis on this problem next month.
Pretty sure the situation describes a failing input shaft bearing, not the throw-out bearing. Either way, pretty disappointing for a transmission with only 39k miles on it.
Old 06-28-2018, 08:50 AM
  #12322
ANMVQ
ANMVQ's Avatar
John, I'm sure you can get it replaced for less than $1000. I wouldn't say dismantling the transmission, Just replacing the clutch, flywheel and TB.
Old 06-28-2018, 09:18 AM
  #12323
In the context of unexpected repair bills... $1000 sucks big time.
I understand replacing the two bearings, but why replace the clutch and flywheel if it's just the bearings that are going? These are not parts I want to upgrade. Driven a few cars with aftermarket clutch/flywheel mods, and I genuinely don't want this. It certainly makes the car more aggressive and is a performance mod, but it's also freaking brutal, and I don't like it.
Old 06-28-2018, 09:44 AM
  #12324
r2dmax
r2dmax's Avatar
While I do agree that a $1000 repair sucks royally, honestly in my opinion, you have to pretty much pull those parts to get to the bearings. So the labor cost is pretty much covered. Also, I do believe that some parts that go bad can directly affect the longevity of related parts. Even if you don't want to upgrade the clutch, there are usually aftermarket options that don't necessarily increase clutch stiffness but that may be better quality than OEM and similar, if not less, money overall. I'd hate for this to be a potential concern in another year or two.
Just my $0.02
Old 06-28-2018, 09:46 AM
  #12325
Lego_Maniac
Lego_Maniac's Avatar
I would think parts alone would be close to $1K.
I've always been under the impression the 6MT was the weakest link in our cars, which was a determining factor in opting for the extended warranty.
Sucks, I wonder though, considering how little you drive, if you can just ride this out until it completely fails.
Old 06-28-2018, 10:49 AM
  #12326
That has occurred to me. Now that I'm attuned to hearing the situation, I can monitor if it gets worse. Or at least, I hope I can tell if it's getting worse. At that point I think I'll have zero options except to get the transmission repaired. You may recall, I lived with a squeaky rear damper for an entire year before swapping the OEM dampers back in. Granted, that literally was less than 3000 miles.
Anyway... in July I'm going to have my mechanic flush & fill coolant, brake and clutch fluid. While there and on the lift, I'll have him assess this problem. The more research I do on the symptoms, the more convinced I am that it's the input shaft bearing, and that's something that could be like this for years before becoming a serious problem, if ever.
In the meantime, the conversation with my wife will be awkward.
"You said you wouldn't spend money on the car this year."
But this is a repair.
"Why would this be broken with so few miles?"
Because it is.
"Why repair something on a car you barely drive?"
Because it's broken.
"Why do you even own this car?"
Good question.
This here, at the 20 sec mark, although in my case the chatter is much, much quieter than this racket, but essentially the same situation. Input shaft bearing.
Old 06-28-2018, 11:29 AM
  #12327
Lego_Maniac
I recall. I also know, and I say this because I've been there, that as an enthusiast, something like this can completely taint what amounts to a hobby.
Because it is.
Good question.
That's a slippery slope, especially where you are with kids and college--ghost of Christmas future for me. The logical next step in ones spouses mind: why do we need this aggravation and expense?
Old 06-28-2018, 11:36 AM
  #12328
Yes, I know. And I know that you know that I know you know.
Sigh.
Again, yes. Exactly. The next 8 years will be filled with college expenses, and there will come a time, quickly, where the car will start looking like a money pit.
Old 06-28-2018, 11:38 AM
  #12329
ANMVQ
ANMVQ's Avatar
Agree'd that a 1k out of the blue repair sux. But I'm was looking at prices for replacements OEM replacement parts "Valeo cluthc kit" was only $280.99, and I have read different things on the flywheel, you can reuse it, you can't reuse it. Sorry I have never had a Infiniti 6 spd so these are things I have read. But when I did my 6 puck on my EVO 8 and lightened flywheel I spent under 1K on everything. :/
Old 06-28-2018, 12:41 PM
  #12330
Nico-derm
Nico-derm's Avatar
Added a couple more words for your responses
Because it is 9 yrs old and things wear out.
Because it's broken. And it is cheaper than recurring car payments.
Good question. ... because we don’t have payments left
The following 2 users liked this post by Nico-derm:
ngolbuff (06-29-2018), r2dmax (06-29-2018)
Quick Reply: Sedan Chat Thread
