Noob Question / Brake Fluid Flush - ATE Super Blue Racing Brake Fluid
I am getting ready to do a brake flush myself, on my G37 and I wanted to know if using a non-Infiniti brand brake fluid such as Super Racing Blue Racing Fluid is ok for the warranty?
Cheers!
Cheers!
ATE Super Blue Racing Brake Fluid Dot 4 : Amazon.com : Automotive
Cheers!
Cheers!
Telcoman
DOT 4 is fine. Just one thing to note about the Super Blue, the dye is illegal for use in Florida. You won't get stopped for it, but you could be fined or ticketed for it if it comes down to that.
Non-Infiniti brand fluid is fine. There isn't such a thing anyway. The only Nissan-branded fluid is the one they "exclusively" make for the GT-R.
oldschool33 (04-27-2013)
i wouldn't do the blue stuff while under warranty, ate 200 is actually the same fluid but doesn't stain your lines blue if you want to use that stuff
i personally use motul but its about twice as expensive and not really needed unless you track the car. i just love the pedal feel it gives me though
i personally don't know how infiniti is about that stuff, but i just hate all that blue in there...its quite easy to figure out when you've gone through the whole fluid if you go through more than a half bottle of the ATE.
also, why do you need to do a full flush? i only ever did that on my race cars, it really doesn't matter on a street car.
Just say no!!!!!
If you're going to bleed it, why not do a full flush. You've already opened the bottle of brake fluid. It all mixes eventually after enough driving and braking. I really don't see bleeding it partially as very useful. ymmv
On that note, how many quart(s) are needed to flush out the system on a sedan with the bbk brakes? I mention sedan because coupe likely has shorter length lines.
My biggest gripe with the blue fluid is that it does stain. At least it did on my Maxima. Which makes it a little trickier to see at a glance if your new amber fluid is still clear. Then again, a test strip can always be used.
The only time i bleed a little here and there is if i suspect air in the lines.
Motive PowerBleeder FTW! It makes changing fluid/bleeding almost fun, and damn easy. I actually dont mind doing the recommended full replacement every year or two. Sometimes its a little bit of a pain to setup and get sealed to the master cylinder....Ive been considering making my own attachment using a spare master cylinder cap and a plastic barb fitting threaded/glued into the center of it.
As for fluid, look for Castrol LMA. AutoX-ing friend of mine swears by it, so for a daily driver it has to be just fine. Plus its clear so no dyes to worry about.
^ Wow, pretty penny. How's it working for you though? Curious, and it's always a good excuse for a new toy.
Thankfully i never had problems with the Motive. If i had to nit, it's that the cap is very tight to put on, which isn't necessarily a bad thing for sealing purposes.
