15mm spacer wont fit
Hey everyone
So I recently purchased the H&R DRM series 15mm spacer. When I try to install it on my car, the original studs are sticking out of the spacer so I cant fit the wheel on the face of the spacer.
I was wondering if anyone has similar problem to that and what are the solutions to it?
Thanks in advance for the help!
Well that does suck. According to this thread, 15mm spacers work fine with the OEM wheels.
https://www.myg37.com/forums/g37-sed...er-or-not.html
Wait... which OEM wheels are you talking about here? I'm going to go out on a limb and suspect you have the non-Sport rims. Or maybe yours are aftermarket.
Oh yeah, Im running on my set of winter tires/wheels right now and I do not have recess behind the wheel. If Im planning to get aftermarket rims for the summer, would the DRS series be a better choice?
in my experience, the drms work with oem wheels BECAUSE there is a little cavity for the original studs to portude into. HOWEVER, i switched over to a set of the 370z stun rims (and i believe this is also true for their oems and many other aftermarket rims) and there is NO cavity and thus you CANNOT bolt on the DRMS unless they're 25mm or greater. 20mm seems to barely make it, but does not clear by a 1-2mm if you look closely.
solution: you'll have to go with drs, stud replacement type, if you want that size spacer with your current wheel setup. they aren't as "bad" as everyone makes them out to be. as long as they're purchased and installed correctly, you'll have no problems. heck, there are many people that track on them.
I had H&R trac+ 20mm DRS spacers on my 2 previous FX's and had them installed and un-installed by my Infiniti Service.
Try your dealership's Service and see if they can do the install.
They OEM studs only need to be "knocked" out with a hammer...replace them with the extended studs.
Here is the install from InfinitiScene on a FX...should be the same procedure:
Wheel Spacer Install
2012G37
06-03-2018 06:59 PM
nbast
09-14-2015 12:39 PM
