MyG37
MyG37 (https://www.myg37.com/forums/)
-   G37 Sedan (https://www.myg37.com/forums/g37-sedan-348/)
-   -   2010 G's are now on Infiniti.com site (https://www.myg37.com/forums/g37-sedan/203461-2010-gs-are-now-on-infiniti-com-site.html)
bobmcc Jan 15, 2010 08:04 PM
The 2010 G coupe and sedan are now showing on infiniti.com
mw09g37 Jan 16, 2010 05:52 AM
... what are the 18" 9-spoke Aluminum Alloy wheels
it's a 1600 dollar package.
and it doesn't look like you can get the aero kit anymore with the tech package...
why is it that a fully equipped G is never possible.
da mayor Jan 16, 2010 09:20 AM
you can always add the tech package from the dealership. i think it's the lip clearance of the ICC sensor.
Canadian144 Jan 16, 2010 10:48 AM
I think that maybe the 9-spoke wheels are the ones that are shown here:
https://www.myg37.com/forums/picture...etail-pix.html
btw da mayor, if I were to get a Sport bumper cover from ebay to put on my X, how many other parts would I require to fit it? I know I would need to get lower grilles, the grille from my current bumper, anything else? It looks like the sensor from the ICC would need to be relocated.. or is that another new part?
Sorry if it's too off-topic...
netmag Jan 17, 2010 12:09 AM
The 9 spoke text might just be a mistake in the configurator. If you go under the "Specs and Options" page, it says that it is a "split 7-spoke" 18" in that package. It also says the same in the pdf specs sheet they released earlier. If so then it's probably the forked 7-spoke rim from the US G's a few years ago. That's what they're using as the 18" in the Korea 2010 G:
https://www.myg37.com/forums/g37-sed...-in-white.html
This also is apparently the 18" rim being used in the European 2010 too:
Image: 2010 Infiniti G37 Sedan - The Car Connection
Not sure because you'd think if they were going to charge $1600 for it here in the US that it would actually be something new to the US. However, when they say "split" 7 spoke, they only thing I've seen that fits that description are those forked 7 spoke 18's.
netmag Jan 17, 2010 01:05 AM
Well, I guess they do show these 9 spoke 18's at the bottom of the accessories page:
2010 Infiniti G37 Sedan | Accessories | Infiniti USA
So then I don't know what the split 7 spoke text is all about under the "Specs and Options" sheet.
Add to it that this guy took a pic of a 2010 journey where the dealer had put what he calls the 18" option package on it:
https://www.myg37.com/forums/2835171-post22.html
This one is indeed the split 7-spoke 18s from a few years ago. So I don't know. I assume then that both the 7-spoke and 9-spoke ones must be available. The 9-spoke ones must be the $1600 option. Don't know how much the 7-spoke would be if it is even truly an option package.
rohardi Jan 17, 2010 09:14 AM
How about the fact that I can't get a Blue Slate G37XS with graphite interior, aluminum trim with nav and premium when I add the Tech package...
Your Selection Requires Changes
The vehicle configurator identifies popular option combinations. Some individual options are only available in combination with others. The one you have chosen requires additional changes.
Your selection of Technology Package will alter your price from $42,745.00 to $44,445.00 and will require the following adjustments:
Graphite Leather / Shodo Aluminum will be removed.
Graphite Leather / Maple Accents will be selected for you by default, but other alternatives are available.
Interior Accents Package will be added.
Would you like to make this change?
› Yes › No
© 2026 MH Sub I, LLC dba Internet Brands
