MyG37
MyG37 (https://www.myg37.com/forums/)
-   G37 Coupe (https://www.myg37.com/forums/g37-coupe-239/)
-   -   window won't go back up to its original position (https://www.myg37.com/forums/g37-coupe/297216-window-wont-go-back-up-to-its-original-position.html)
G37Bu Jul 27, 2020 12:44 PM
👋🏽 , the title says it all.. the windows goes up and down. but when i close the door the window won’t go up to it’s original position automatically. i’ve lowered the window a bit so it won’t hit and shatter the glass. so there’s no gap between the door frame and the window.
i tried to reset the window by holding it down but it didn’t work.
my battery died and i had to change it. since then, my windows doesn’t work properly.
any tips or recommendations are welcome. :-)
edit: i have a 2012 G37x coupe
Surfnazi Jul 27, 2020 01:42 PM
Make sure your door switch isn't bad
Birdie Jul 28, 2020 03:18 AM
Are you sure you are resetting it properly. remember hold it down till the window is all the way down. Continue to hold it for about seven seconds then go up with it till it hits the top with the door closed of course. And hold it for another seven . good way to tell if it's done properly is push the button down all the way to see if it rolls down WITHOUT you having to hold the button.
G37Bu Jul 28, 2020 02:44 PM
I'll check it out, thanks !
Джон Aug 8, 2020 05:30 PM
Thats an easy one.
you need to do the recalibration.
if it didn't work it's because you did it wrong.
Thunder18 Apr 3, 2022 07:55 PM
Thanx for this advice!!..the windows wouldn't roll all the way up after I replaced the battery on my 2012 G387 convertible..I rolled the wim=ndows down and held them their for 5-10 seconds...I then raised them and held them up for about 5-10 seconds..this did the trick!!..thanx folks!!
© 2026 MH Sub I, LLC dba Internet Brands
