Axle Leak?
Old 06-15-2019, 09:26 PM
sLADe781
sLADe781's Avatar
Axle Leak?
Hey guys,
While bleeding my clutch fluid today, I notice a wet spot under the car. I think it may be my driver side axle?
I've never seen any drips on the garage floor before but the area is clearly wet.
Is this a sign that my axle is going bad? Do I maybe just need to tighten the bolt there? If so, anyone have any ideas on what the torque spec is?
Thanks in advance.
Old 06-16-2019, 06:13 AM
Received 4,574 Likes on 3,425 Posts
That's the steering rack tension nut. PS fluid weeps through somewhere and builds up around that nut. It's really common and doubtful there's a problem. Do not mess with it, just wipe it down, keep a weather eye on your PS fluid level, and check it out next time you're under the car.
Here, read this: http://www.the370z.com/engine-drivet...ring-rack.html
sLADe781 (06-17-2019)
Old 06-17-2019, 09:43 AM
sLADe781
sLADe781's Avatar
Here, read this: Something leaking at the steering rack - Nissan 370Z Forum
Thank you sir for the response and the link. Very much appreciated.
In other news, the post got moved and it took me awhile to locate it. lol
Old 06-17-2019, 09:50 AM
You're very welcome. I had the identical concern about the steering rack some years ago.
Moderators move threads around at their discretion. Don't sweat it.
Use your profile, go to the "Statistics" tab, select "Find all threads started by sLADe781". Or easier yet, go to your Control Panel and view all subscribed threads.
jpowersjr2 (06-17-2019)
shiftz33
04-27-2015 10:31 AM
LSUg37
05-20-2008 10:37 PM
SteveG37
13
02-17-2008 02:17 PM
Quick Reply: Axle Leak?
