Need part number
Need part number
Can anyone here provide the part number for this harness? I would surely appreciate it because I just aquired a set of illuminated kick plates for my 2008 coupe and need a t-harness. Thanks, Joe
Copied from an older thread.
This is what the T-Harness looks like:
It should have been included in the kit. Did you buy the kit new? While the harness makes the install a lot easier, if you have basic skills you could just hardwire the kickplates directly:
The T-Harness is not available separately. In all honesty, you would be better off just hardwiring the kickplates directly to the BCM harness. There is very little free space around the BCM and the T-harness makes things very tight.
That said, if you really want the T-harness I have one somewhere in storage from when I bought the Skyline plates. I could pull that harness and send it to you- though it would take several days before I could post.
I pulled it from storage so pardon the dust:
Too easy
I received the T-harness today from ILM-NC G37S, thank you so much!
This has to go down as one of the easiest mod installations I’ve ever done. I received the illuminated kick plates yesterday from a buy on fleabay. The seller did a really great job removing them from the donor car without bending and causing wrinkles in the metal. Hell, I spent more time prepping them with new 3M double sided tape than it took to run the harness inside the car.
I feel that hooking the lights up went so fast because of having the harness. Which by the way, is not as large as some might think. I have average size hands for a comparison to the size of the harness.
A google search shows a post on Nico of a led strip outside and under the body connected to the t-harness.
Thanks in advance.
Stock photo (of Maxima):
I installed Nissan p/n: 999F4-AX008. The kit is technically for the Altima Coupe but the parts are generic for any model. The following is not a great picture but here it is on my car (ignore the kickplates, they have been changed out for Skylines):
eddiealiano
11-02-2017 11:07 PM
TeRRoRiFiC35
Intake and Exhaust
06-02-2012 02:37 PM
