Coolant question
Old 01-13-2018, 08:51 PM
Dan G37
Dan G37's Avatar
Exclamation Coolant question
I was wondering if anyone could help me out. Today I popped the hood in my car and realized that the coolant in the flow reservoir is quite low.
Is it fine to top it off or should I do a full coolant flush?
Live In Minnesota so it is quite cold here.
Old 01-13-2018, 11:33 PM
guy from norcal
guy from norcal's Avatar
Well if your due to flush the coolant, You should. If not just top it off.
Old 01-14-2018, 12:14 AM
JSolo
Just say no!!!!!
JSolo's Avatar
I'd look in the radiator too, I bet that's also low. Top off the radiator then bring up the reservoir to the full mark.
Inspect both after driving for a week or two.
Old 01-14-2018, 12:36 AM
Dan G37
Dan G37's Avatar
I'm just stupid! Didn't realize the coolant went so low, its between the MIN and MAX line. I will flush in the spring when its not so cold out!
Old 01-14-2018, 03:51 AM
FlashGuy
FlashGuy's Avatar
I would just top it off and check it in a few days. If it's low again then check for leaks.
The manual says the top off procedure is to just fill the reservoir.
tite_tite
09-25-2015 10:21 PM
steven92
09-18-2015 12:04 AM
JSolo
General Tech Questions
07-09-2015 01:57 PM
08-06-2010 12:47 AM
Quick Reply: Coolant question
