Electronics turn on and off when driving - HELP
driving this morning I noticed that my gauges and radio and everything turned on and off rally quick. Flickered. Did that twice. I don't think the engine turned off. Hard to tell. But other thing I noticed was my car turns on pretty roughly. Just now as it turns on it makes a loud click noise when turning on. The car would stay at a steady 14.7 volts when driving after it flickered. I'm afraid my car will die when driving... Any suggestions?
Yes! For starters
Check both the positive and negative battery cables for corrosion. If you can move either one by hand they are loose. Tighten the battery clamps.
Telcoman
Yes! For starters
Telcoman
But if the battery is disconnecting wouldn't that re set the ecu. Like my mpg would be zeroed out. My saved profiles would be cleared and stuff. Which didn't happen.
r1vaL
11-29-2018 08:10 PM
gian13
11-26-2018 04:15 PM
