Squeaking/Noise from Chassis (Suspension?)
Old 06-28-2018, 10:22 PM
GW330
GW330's Avatar
Same exact sound under the same situation.. hot day + driving for a while, squeak city!
Changed to coilovers, changed the end links, did not help with the sound..
Replacing lower control arms (need replacement according to the dealer) and swaybar bushing soon, hopefully it fixes it.
08 coupe with 66k miles.
Old 06-29-2018, 05:03 PM
TuckerE36
TuckerE36's Avatar
Have a 08 coupe (sport, 29k miles) that is having the exact same front suspension noise when hot. Stock suspension, my thought is it's coming from the LCA's...
Old 06-29-2018, 07:32 PM
Rollo
Rollo's Avatar
My old sedan started squeaking over speed bumps and I lubed the sway bar(I think) bushings to make it go away.
Old 06-29-2018, 09:27 PM
slartibartfast
slartibartfast's Avatar
Lubing the bushing is low-hanging fruit and quite inexpensive. Try that first before replacing parts.
Old 06-29-2018, 09:55 PM
G37xS-Life
G37xS-Life's Avatar
Do you guys by any chance have a zSpeed aluminum engine undershroud? For the longest time, I had the same squeaking sound over speed bumps and while traveling at low speeds (below 15 miles per hour). As it turns out, my zSpeed aluminum shroud was flexing and rubbing against the Hotchkis sway bar and that was where the squeaking sound was coming from.
Old 07-04-2018, 06:18 PM
Surfnazi
Surfnazi's Avatar
Originally Posted by sbowden99
I assume you mean lube the sway bar bushings?
Yes degrease the bushings
Old 10-04-2018, 11:59 AM
JohnnysG
JohnnysG's Avatar
Worn rubber bushings can squeak during deflection.
Are you talking about the lower control arm bushings?
Old 10-04-2018, 02:27 PM
slartibartfast
Yes. American cars were particularly bad about this but rubber selection has improved and I don't hear it much anymore.
Old 06-24-2020, 08:03 AM
Oocphil
Oocphil's Avatar
what was it
did you ever find the issue???
I have a 2008 Journey (stock everything), and I have the same squeak under the same conditions as described above. If anyone finds a solution, please post.
g37s_
06-01-2016 11:14 AM
reachout
05-23-2016 11:47 PM
Ricio1991
05-21-2016 05:56 PM
MilehighG37s
05-21-2016 09:57 AM
IracknBack
05-17-2016 09:42 PM
Quick Reply: Squeaking/Noise from Chassis (Suspension?)
