Cleaning MAF Sensor
Ttt
Reviving this thread for a quick response and see if anyone else has had this problem. About 3 weeks ago my 2009 G started to act up and stutter but only at idle, I took it to a mechanic and his ran a code and informed me that it was a misfire but could determine in which cylinder because he didn't have the right scanner for it. I had an extra Ignition coil from a previous MOD and I started to change out one by one to find out which cylinder it could be. Well it idled pretty much the same but it did stop the stutter. But last night as I was driving on the freeway it started to stutter again really bad, so I got off the freeway and pulled into a parking lot and drove it slowly noticing that the car wasn't shifting when it was supposed to. So I manually shifted back home really slow and it would bog down at idle almost turning off once i pressed the gas lightly. I borrowed a bluetooth scanner from my neighbor and ran it and it gave me a P0101 (MAF) code. I found this thread and went out and bought some CRC and new air filters after I saw how torn up the pass side was and cleaned them out and now the car seems to be running ok (still idling a little rough) but I have not driven except around my neighborhood. Has anyone seen or experienced this? I just want to find out if I went the right way before I spend more money then I have too. (See pictures below)
Wow. How long were those filters on? Please let us know what brand those garbage air filters were so no one else here buys them. A blowout like that should never happen, and the wrinkling of pleats on the other side is really bad as well.
As for the fix, If the car doesn't give you any problems, it's fixed. The maf code was probably caused by the torn filter causing anomalous readings.
vdpinc01 (11-12-2017)
Thanks for your feedback.
They look an awful lot like the pentius filters In my mothers EX. Just checked them and the pleats are a little wavy, but nowhere near that bad (then again, my 67yo mother isn't known for going WOT all over the place). I think I'll replace them sooner than later anyway.
I almost want to say that they were WIX filters. That is sticking out to me right now. But I'm going to do some running around in a couple of hours and I'll update the results.
Wix filters are yellow filter medium with orange surrounds. I've used them before (NAPA Gold store brand) and they're actually top notch.
I honestly don't remember what brand they were, I bought them about a year and 3 months ago. (my bad) I do remember they were about 15 bucks ea though so I thought i was getting a decent set of air filters. I normally go with Fram or something aftermarket but that time they didn't have any in stock and figured I would change them out sooner. But hey, Life a way finds a way to get in front.
Buy cheap and you'll buy twice.
I change my air filters every 10k miles
Takes 3 minutes to replace both of them
Telcoman
I see no reason here to spend $50 on a set of OEM filters and replace them 3x as frequently as the recommended service interval. Maybe a good reason to avoid no-name filters of foreign origin, but I've never seen an air filter of reputable manufacture blow apart like that or even perform significantly different than a factory one.
Thanks again for your input.
The slightly rough idle is pretty typical for these cars. I've done all the things that allegedly help: cleaned the throttle bodies, maf sensors, fresh transmission fluid, everything helps to some degree. Frankly, a bottle of techron in the gas tank helped as well as anything.
#29
For paper filters, i usually use Napa Gold, which is a store-branded wix filter.
vdpinc01 (11-13-2017)
#30
Thanks.
