spacer kit so i don't have to cut factory studs?
I bought an eibach pro kit for my 2012 IPL & looking to get either 15mm or 2mm spacers all around. now my one friend was telling me not to buy the spacer kits that come with additional nuts/bolts cause Ill have to cut my factory rods in order to fit the spacers. He told me to find a spacer kit that i can simply slide on to my factory rods then slide the rim on after.
Who makes these kind of spacer kits? All I can find are the spacers that bolt to your hub then another set of bolts to your rim. I can't find these spacers he is talking about? Any help would be great
Because Racecar
Ok so your saying 20mm spacers won't work cause i won't really have any thread left on my factory studs in the first place and its dangerous.. My friend was saying if I do 15mm spacer I can still comfortably use my factory studs . However i don't believe him cause he has a volkswagon lol is 15mm spacer possible and if so who makes these?
For spacers I would recommend H&R (a bit pricey but high quality) and for the type that you are looking for is called H&R DRM Trak. The DRS type is when you have to replace the whole hub and bolts. DRM is simple plug and play (no cutting.) When installing, remember to torque wrench in star pattern going from 20lb-40lb--85lb of torque. I have mine 20mm front and 15mm rear, there is no wheel vibration. Also, H&R spacers design will give you plenty of thread on the factory studs because the slots where it goes to the factory studs will be indented. Hope this helps
http://www.hrsprings.com/products/trak/
Because Racecar
If you are using factory wheels. Go for the bolt on spacers. No cutting of stock studs. They are simple bolt on. They look like this.
I offer my own B2designs spacers. 1pc hub centric. Lots of positive feedback. Check them out.
https://www.myg37.com/forums/wheel-a...plication.html
Also when installing spacers. Always use a torque wrench. Never use impact. 6 point socket is best also.
Charles
Charles
H&R TRAK+® Wheel Spacers | Products || H&R Special Springs, LP
Thanks Teonguyen,
i found a set on stollen website below:
http://www.stillen.com/product/wheel...663-41060.html
I'm still thinking i will have to cut my stock studs? Will the above link work for my g? Also why did you go 20mm front and 15mm rear. Whats size tires you have?
Thanks Teonguyen,
H&R 15.0mm DRM Type TRAK+ Wheel Spacers 3065663 HR3065663 | STILLEN
One other thing, be SURE to recheck torque after a few hundred miles & EVERY tire rotation, also DO NOT use any thread-locking compound on the lugs or spacer threads.
Thanks Teonguyen,
Yes the link above will work, but best bet is to contact any vendors in this forum for best pricing. No you you wont have to cut anything just plug them on the factory hubs torque then re-torque after couple hundred miles like blnewt mentioned, then it will be all set. I still run stock size tires 225 F and 245R and was planning on going 245/275 that why I went 20F and 15R. I wish I went all 20mm all around cause with deeper drop the rear looks a bit tuck with 15mm. With Eibach mild drop I believe you can go 20 all around. Also, hear lot of positive reviews on B2autodesign spacers. Charles @ B2autodesign will help you out. Bought a lot of parts from him.
Charles
Charles
Lt8Che
91
04-08-2022 04:55 PM
i heart ricers
12
12-09-2015 04:15 AM
