How to remove center console of 08 G37S
08-04-2013, 08:24 PM
Guys I'm trying to remove it to carbon fiber wrap it right now and can't find instructions , if you guys can help me out that would be great!
08-04-2013, 09:49 PM
08-04-2013, 11:41 PM
Well after your finish w/ everything, post up some pix
08-05-2013, 04:42 AM
For MT's you unscrew the shift **** and gently pull the center console out. Then you'll see two screws that hold the center trim piece.
08-05-2013, 10:38 AM
Just did both doors , next is center console!
08-05-2013, 11:18 AM
Nice looks good, btw on the center console you have 2 screws where the arm rest opens, pop out the black strip to expose them.
08-05-2013, 11:41 AM
Quote:
Originally Posted by
Doubleminded
Ok, I'm going on vacation now, so I'm going to begin when I get home
08-05-2013, 05:10 PM
Did the same thing about a year ago with the gunmetal color vinyl wrap..
08-05-2013, 05:18 PM
Attachment 98061 here are some pics..
08-05-2013, 05:23 PM
Looks good so far. In for the completion of everything.
08-05-2013, 05:28 PM
If its an auto then there are two screws behind the bottom plate that is in front of your ash tray. Then two screws at the very back as you pop off the rear panel on the center console.
You pull down on the bottom of the shifter where the silver part is then there is a tiny clip on the shifter where you have to pull out towards you and then just lift everything and you should be fine. Remember though, lots of wires connected under it.
08-05-2013, 05:32 PM
^ It's an AT judging by the cluster
08-05-2013, 06:31 PM
yea mines an AT, i just dont know how im going to wrap the console without being able to remove just the silver lining
08-06-2013, 01:12 AM
The silver part in the middle pops out by itself too. It shouldn't be. Problem. It all comes apart.
SS2006
09-29-2023 06:34 PM
Lt8Che
91
04-08-2022 04:55 PM
Munts
08-21-2019 10:21 AM
G37xhibeet
11-15-2016 09:29 AM
Skeletor06
08-02-2015 12:54 AM
2008 ,
2009 ,
2012 ,
center ,
console ,
coupe ,
g37 ,
g37x ,
infiniti ,
myg37 ,
removal ,
remove ,
removel ,
vinyl ,
wrap
