Rear Bumper Bracket
Hey guys,
after doing research on completely shaving the rear bumper bracket, i figured that it wouldnt affect anything unless an after market fiberglass bumper would be installed... is this correct??? :confused2: how many have done a complete rear bumper bracket shave without any issue occuring after???? i wanna completely shave the entire bracket or maybe move the bolt a half and inch or so further... im wondering if the rear bumper would become flumsy, become loose, wobble etc. if the bolt is completely removed... ive seen bumpers on hondas wobble specially when in the freeway and open road driving... :eek: ... want it to appear and seem as if nothing was ever modded unless you looked underneath... haha |
I did it and have no issues, but then again I drilled a little hole on the lip of the rear bumper where it meets the fender and passed a tie-strap through it just in case. Had done it on my ISx50 for the fronts and worked well also. GL
i thought you did a small shave and that fixed the issue,
are you thinking about doing a complete shave just for the heck of it? or is it still rubbing? |
Mines are completely shaved off too. I used 3m double side tape to keep the bumper in place and not a single issue.
Yes, if you plan on getting a aftermarket fiberglass bumper you will have some problems from keeping it up. What I can suggest is remove the bolt, use a rubber mallet and bend it instead of cutting it off completely that way it's still there if you ever need it. |
Originally Posted by G37-J
(Post 3393037)
Originally Posted by jsp872
(Post 3393151)
are you thinking about doing a complete shave just for the heck of it? or is it still rubbing? not a big issue since im usually with at most a single passenger... but once in a full moon, i do carry two, maybe three passengers and want to eliminate any possibility... thats all... so i guess you can say that its kinda for the heck of it... maybe... :)
(Post 3393159)
Mine is pretty close to being completely off. It was needed for my wheels tire set up to fit. I have no probs.
Originally Posted by P Casey
(Post 3393558)
Shaved and good to go! No rubs even w my +25 and 275z and I'm pretty low. Shave it and look good lol.
Originally Posted by VossenG37S
(Post 3393770)
gonna shave most and then use a rivet... |
http://www.ihatespam.info/song3.jpghttp://www.ihatespam.info/song2.jpg http://www.sunlian.net/3.jpg |
Originally Posted by kartleyBecil
(Post 3393906)
http://www.ihatespam.info/song3.jpghttp://www.ihatespam.info/song2.jpg http://www.sunlian.net/3.jpg ok... great... its good to hear that this is an option which doesnt affect anything... btw... i cant see the pics you posted... is it just my comp??? i also clicked on it and it takes me to some website... can you repost??? would really like to see your pics... |
Yes please fix the links so we can see the pics. |
going to try this tonight. I am rubbing that bracket pretty bad in the rear. Trimmed it last night and still rubbing. Going to try the full shave tonight
Yea, post some pics of how much you all have trimmed.....curious to see myself
Originally Posted by Topher9425
(Post 3434011)
