Notices
how hard is it to install factory OEM rear deck spoiler?
Old 01-12-2012, 11:12 PM
UncleFunkle
UncleFunkle's Avatar
Originally Posted by BlueOut
You'll are payin way to much for your spoiler, I paid 200.00 free shipping with brake light and camera hole..do good research before to purchase
OK, so where did you find this price? Is it OEM or aftermarket OE like the eBay versions
Old 01-13-2012, 02:25 AM
dopetime
dopetime's Avatar
lol its definitely OEM style ebay one. You can't find the oem one for that much unless its a vert.
Old 02-21-2018, 03:43 AM
Davidg0322
Davidg0322's Avatar
Lining up templates
Originally Posted by OB G
First of all, the spoiler that you posted states that there's no backup camera hole so make sure you get the right one.
Second of all, I actually just received and installed mine over the weekend. Took about two hours but I was being super careful because since you're drilling holes, if you get it wrong, there's no going back. Don't take it to the dealer. Mine didn't recommend that I install it myself because it required a "special" drill bit, which is BS. They wanted to charge me 2+ hours for installation too.
When I installed my spoiler, it came with little stickers (yes, stickers) to cover up the old holes from the chrome spoiler.
Since you mentioned that you've installed a lip, I'd assume that it's somewhat similar. Just take your time when lining up the template and you'll be fine. GL.
hey I just got my oem decklid with camera hole just dropped it off for paint cause I got it in blue slate from
the dealer for $175 shipped and $80 for paint from a local shop in kh3 obsidian black. Just wondering I’ve changed clutched engines swaps... etc. is lining the up the deck lids that hard I got the templates and can I use regular titanium drill bits or should I go buy new ones. I have the directions and one of the drill bits says a whole saw drill bit. Please and thanks
Old 02-21-2018, 08:45 AM
NealP
NealP's Avatar
Titanium bits should be fine. I haven't done it myself but I can only imagine if it's saying use a hole saw bit that's because it's a larger hole so unless you have a bit that size you may have to get a hole saw bit. If I were you I'd see what the local shop will charge to install.
Old 02-21-2018, 01:42 PM
Entcee
Entcee's Avatar
Anyone know the part number(s) for the stronger trunk struts?
Old 02-21-2018, 07:07 PM
saywat?
saywat?'s Avatar
^ z1 should have some
Old 02-26-2018, 05:36 PM
kidtronix
Build your own bandwagon.
kidtronix's Avatar
DIY would be nice on this.
RECOMMENDATION: whenever you're preparing to drill into metal, use a punch to create a slight pilot divot. Cover that with tape, then rest the drill bit in that impression so the first turns of your bit don't skip around the surface and ruin the surrounding paint. That way you'll have a flawless hole with minimal distress to its surroundings.
And hey, if you do make a bonehead move and biff your trunk lid, you can always buy another one. Life goes on.
Old 02-28-2018, 12:25 PM
Entcee
Entcee's Avatar
Could only find hood struts. Can't seem to find the part numbers anywhere.
Old 02-28-2018, 03:20 PM
saywat?
saywat?'s Avatar
looks like they have it specifically for the 370z i thought theyd have it for the g too guess not
Old 03-02-2018, 02:09 PM
Chaluska
Chaluska's Avatar
did mine in about 30 minutes start to finish. it was super easy, just follow the instructions
Old 03-07-2018, 12:43 PM
DreamQ
DreamQ's Avatar
Don't be fooled. It is not as easy as some have suggested. Obviously, the drilling is the hardest part. The holes are pretty big and make sure you have the right drill bits for metal surfaces. Oh, and double check that the provided template is correct and the holes line up with the spoiler. (I bought OEM spoiler from Infiniti and installed it at home, with the help of my brother.) Good Luck!
Old 04-21-2018, 09:46 PM
lostOne
lostOne's Avatar
Does anyone know where I can find or download the "template" to drill the holes ? Bought a used OEM spoiler ... Appreciate the help in advance.
Old 04-21-2018, 09:56 PM
Entcee
Entcee's Avatar
I still have the template from when I installed mine. I could send it to you.
Old 04-21-2018, 10:37 PM
  #29
lostOne
lostOne's Avatar
Omg that would be awesome! Can I PayPal you for postage ?? PM me with your PayPal. G37 Coupe yeah??
Old 04-21-2018, 10:39 PM
  #30
Entcee
Entcee's Avatar
Darn, I have a sedan
Quick Reply: how hard is it to install factory OEM rear deck spoiler?
