Front License Plate?
#46
Suction cup that thing to your windshield. The suction cup has a nipple that can fit through the hole on a plate. There is another small hole in the nipple, of the suction cup, that a small plastic post fits into. When applied correctly, your plate will stay suction cupped to the front windshield.
#47
^ Front plates in the windshield are only legal in a few states.
@bruin - The factory plate bracket has two holes drilled in your bumper for mounting. You need paint matched bumper plugs, and even then it's not the cleanest.
#48
what brand/company did you use for yours if it did hold up?
#51
Senior Citizen
You can’t have it both ways. If it’s just lying on the dash it can’t be read from the street. If it’s secured on the windshield with suction cups then it’s blocking the driver’s vision. Either way, most courts would rule against you.
#53
Suction cups inside the windshield isn't securely mounted. What's to stop someone from taking it down at will to keep it from being read by law enforcement? Or if someone is pulled over, just taking it off of the floor and putting it up there really quick? Or when it becomes a sharp edged projectile coming toward your face in the event of a severe crash? Can't do that if it's mounted on the front bumper. Unless you have an electronically controlled hideaway plate.
#54
#55
What I'm saying is that in Texas it has already been interpreted. There have been suits filed. Cases decided. The decision was that a plate displayed anywhere inside the vehicle doesn't meet the requirement of the Texas law. You could try taking yet another case before the courts, but it wouldn't likely do any good. You are going to pay the fine. Is it really worth hiring a lawyer for a $100 citation that isn't a moving violation and that will be dismissed anyway if you just put the pate on the car?
#56
Senior Citizen
BTW, in California nothing is allowed on a windshield except for a 5” square on the lower left of the driver’s side (7” on the passenger right side) for GPS devices. That means a license plate in any windshield position would be illegal due to its size.
#57
It might block your view of the hood. But you can still see all the areas you need to just fine. I'm from a different state so I won. I never paid a fine while my tag was there. Now I have a different car, I don't even display my front tag.
That's why I'm say that the OP needs to check out his state laws. It's different everywhere you go..
#58
Actually my comment stands. Windshields cause some distortion around the corners and especially from an angle, which is exactly where you would mount the plate. The lenses cause a similar effect, though far more drastic. I do think about things before I just throw **** out there. There's also the matter of glare and reflections.
#59
#60
