Anyone with A/C problems?? I'm already dry. Possible leak?
I have an 08 37s and my a/c is completely out of freon. A buddy works for nissan said its not normal and he hasn't really seen any z's or g's come back with a/c problems except with air intakes. My lines look good, except I have to take the front shroud off to check the lines up front. I'll prolly run some dye through to see if there is a leak. I'm wondering if my stillen gen III's came into contact with any lines and rubbed through somehow. Anyone else experienced anything like it?
I have Gen 3's, but haven't experienced it.. One thing that comes to mind though, is during the Gen 3 install (where you have to enlarge the core support) you'd come to very close contact with the fragile metal A/C lines, thus creating the potential to damage them causing a leak.
Ill have to check it out. thanks for the heads up
Maybe you could just remove the whole climate control system to save weight... :dunno:
I'd say it's not normal too. I have an '08 and my air conditioning is still fine.
You definitely have a serious leak.
2 Attachment(s)
Definitely a serious leak.... Anyone with Stillen gen III's be careful if they rub your ac lines. I even tried to bring them higher on their mounts but it still rests on the line. I am going to have to get a new line and tweak it a little and wrap it in tubing to make sure it doesn't rub through again
Attachment 172993 Attachment 172994 |
Originally Posted by ECain18
(Post 3136793)
To keep it from rubbing your AC line and causing a leak, buy $1 worth of rubber heater hose in the appropriate diameter and slit it down the side. Wrap it around the AC line to insulate it from the abrasion. Volila!
^^ BB, Spell check VIOLA! lol, but yes, what you said will prevent alot of headaches.
Originally Posted by D_S_CUSTOMZ
(Post 3151894)
Who's playing a viola? |
yes wrap the AC line or intake . I know that the intake pipes get too hot.
Yep, i was gonna wrap it in some rubber hose exactly like blackbetty described. Should take care of it then
No ac
(Post 3151389)
http://i763.photobucket.com/albums/x...9/IMG_0323.jpg http://i763.photobucket.com/albums/x...9/IMG_0322.jpg Thanks |
1 Attachment(s)
Have the same issue by any chance do you know the name of that line
| All times are GMT -4. The time now is 12:08 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
